Thread: Front wing Funk
    Senior Member suzrm121's Avatar
    Bellingham, WA
    Liked: 6
    Default Front wing Funk
    As you can see in the picture my Left front wing (right side of photo) has a little twist in it.
    Is is possible to unfunk it with out hurting things or drilling out all the rivits and relaying it? It seems structurally sound and I see no reason it should be in a bind.
    Please pay no attention to all the crap on the floor in the garage, it has been a long couple days/nights getting all the new body work on a fitting correctly
    Somerset, Kentucky
    Liked: 126
    Looks like the steel wingpole might have a slight tweak in it. Take the wings off and look at the pole. I've been able to straighten them enough at the track, but they end up being weak - and then I end up making a new one at home.
    Those are typically cheap round steel. I've tried aluminum, but I now make them out of steel again.
    Bellingham, WA
    Liked: 6
    Default Strait and True
    Ive checked the bar for straitness and even lazer leveled the thru hole in the crush box and flipped ends of the bar to triple check, I think it is a twist in the cord axis?
    Senior Member kea's Avatar
    madison heights,mi
    Liked: 600
    Default Wing Twist
    I could make you a new one !
    Averill Racing Stuff, Inc.
    www.racing-stuff.com
    248-585-9139
