Results 1 to 2 of 2
Thread: Coil Location
    Senior Member R.DeVoe's Avatar
    Philadelphia, PA
    Default Coil Location
    What is the best location to mount the ignition coil (Kent motor)? As close to the distributer as possible without heat soaking from the engine bay? Doesn't matter?
    "The winner ain't the one with the fastest car, it's the one who refuses to lose." - Dale Earnhardt Sr.
    Liked: 909
    Shorter wires are always better. But put it away from heat.
    If you have side pods, unless the radiator exit is in the rear of them, put it in the rear of the one on the distributor side.
