Home
ApexSpeed Portal HomeApexSpeed Reader GalleryApexSpeed.blogsApexSpeed AdvertisingForums
Go Back   ApexSpeed > Formula 600 > F600: Car Building & Technical
Reply
Thread Tools
Old July 22nd, 2012, 5:36 PM   #1
jacob280zx
Default Building a F600 chassis from home
Hi Im 15 and would like to build my own chassis. My dad works at a machine shop so materials are not a problem, and I think I'm comptent in the design deparment. I would also like to make it myself because then I could custom fit the cockpit and chassis design to my liking. One question though where would you get elastomeric pucks.
Thanks Jacob
jacob280zx is offline   Reply With Quote
Old July 22nd, 2012, 5:41 PM   #2
iamuwere
iamuwere's Avatar
material can be had at mcmaster carr
urethane sheet cut to rounds or round stock cut to thickness
iamuwere is offline   Reply With Quote
Old July 22nd, 2012, 6:36 PM   #3
jacob280zx
what is the lowest ride hieght because I can't find it in the rules. I think its 2.5 inches but can some one verify that. And thanks for that website very helpful
Old July 22nd, 2012, 8:16 PM   #4
fatdaddy53
Ride height is as low as you dare to go, 80inch wheelbase, 55 inch max track. You can find the material requirements in the GCR at SCCA.com.
fatdaddy53 is offline   Reply With Quote
Old July 22nd, 2012, 9:22 PM   #5
iamuwere
iamuwere's Avatar
By some of these questions, I have to ask how much F500/F600 experience you have. I don't mean that disrespectfully. There are a lot of design considerations for one of these cars to make them work well (or even safely).
Old July 22nd, 2012, 9:41 PM   #6
F five hunj
Good luck, there's a lot to consider. If you haven't already, try and put eyes on one locally to study the design. Some cars are a little better thought out than others.
F five hunj is offline   Reply With Quote
Old July 23rd, 2012, 8:51 AM   #7
GBugg
GBugg's Avatar
The best place to start is the rule book:
http://www.scca.com/clubracing/content.cfm?cid=44472
Read through it all, but focus on the F600 section in the back. Then I'd strongly suggest you find an F500 or F600 near by if you can and take a good look at existing designs. It will save you a ton of re-work and frustration!!
Have fun with it!!
__________________
George Bugg
NovaKar
F600
GBugg is offline   Reply With Quote
Old July 23rd, 2012, 10:56 AM   #8
Forum Advertiser
Stan Clayton's Avatar
Quote:
Since Jacob says he is 15 years old...I'm guessing not much.
Jacob, just go for it! The first time you finish an event in a car you designed and built yourself, no matter how fast or slow, you will be on top of the world. And I guarantee every other driver in your group will be patting you on the back and shaking your hand!
Remember, every great racing car designer started right where you are.
__________________
Dauntless Racing
Stan Clayton is offline   Reply With Quote
Old July 23rd, 2012, 12:57 PM   #9
formulasuper
formulasuper's Avatar
Yes Jacob, if you're like me you've been building karts, minibikes, ect. from the time you were old enough to turn a wrench & swing a hammer, so like Stan said, "go for it". Remember, "The difference between men & boys is the size of their toys!"
__________________
Scott Woodruff
formulasuper is offline   Reply With Quote
Old July 23rd, 2012, 10:39 PM   #10
jacob280zx
Thanks for the support and soliditfying some of my questions.Experiance in building an actual car absolute 0. But I think I have enough knowledge in the saftey and design aspect of building a chassis. I was thinking something like the early novakar f600 chassis designDSCN7758.jpg or something simple like this. Like I said before my dad works as a machinest so I can get the steel and such for 50% off, which is one of the reason also for attemping this project. Would it also be possible to do this for under 4-5k, because then if someone like me can do this it would kind of be like opening a new door in inexpensive racing.. I woud be using a lot novakar body work and such.
Again Thanks
Jacob
Old July 23rd, 2012, 10:41 PM   #11
jacob280zx
Oh and I forgot I am mechanically inclined. I've been working on cars with my dad in the drive way since I was about 5.
Old July 23rd, 2012, 10:42 PM   #12
F five hunj
Quote:
Again Thanks
Jacob
If you don't already, learn to use some type of solid modeling 3d cad program and build your car there first. You'll save yourself a lot of time.
Old July 23rd, 2012, 10:46 PM   #13
jacob280zx
I was thinking of using google sketch up to build my base plans. I am also going to find out the weight o the fuel cell and such to find out how much the chassis it self is going to have to weigh.
Old July 23rd, 2012, 10:49 PM   #14
jacob280zx
Gbugg I have been doing that which helps a ton.
Old July 23rd, 2012, 10:53 PM   #15
jacob280zx
fatdaddy53, hs also suggested that I get a f500 chassis and convert it. Would anyone have or know of anybody selling a bare f500 chassis in Seattle or Vancouver, B.C?
Old July 23rd, 2012, 10:54 PM   #16
F five hunj
Again Thanks
Jacob
I've been using solidworks to model my car and do various small projects. The educational version is very inexpensive.
Old July 23rd, 2012, 11:03 PM   #17
jacob280zx
I'll look into that. I took a look at the novakar parts price list and checking out components I cannot make myself and the price is over 3k help on findig parts cheaper if possible like brake rotors and calipers, fuel cell, steering rack and box, wheels and hubs, body work, etc.
Old July 24th, 2012, 8:43 AM   #18
Jnovak
Forum Advertiser
Jnovak's Avatar
Go for it Jacob. I doubt if you can do it for $4-5K, but you can buy used parts wherever possible and that will help big time.
I also suggest that you do not do this project without doing drawings or 3d models. Doing it without drawings or models will result in lots of do-overs and mods.
This will be a fantastic project and will result in many great experiences for you. Good luck and do not surrender!
Jnovak is offline   Reply With Quote
Old July 24th, 2012, 1:28 PM   #19
jim murphy
Another approach is to offer to buy a stripped down F500 chassis with the owner keeping all the snowmobile stuff which he can then sell separately probably for more money.
HTH,
jim murphy is offline   Reply With Quote
Old July 25th, 2012, 1:01 AM   #20
jacob280zx
Yeah Jim if anyone is willing to take out the running gear that would save a lot of money. And if anyone is selling any used parts in the Seattle area send me a message
Old July 25th, 2012, 1:08 AM   #21
jacob280zx
I'm also thinking of just doing solo events first just to get started. Then build up enough skill and confidence while I get enough money to take it to the road courses
Old August 6th, 2012, 7:49 AM   #22
provamo
provamo's Avatar
Jacob..................absolutely GO FOR IT !
i am away from my library but will recommend some design sources within a week
provamo is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
©ApexSpeed 2000-2013
