Thread: Master cyls.
    Senior Member captdigi's Avatar
    Phoenix, AZ
    Liked: 123
    Default Master cyls.
    Ok, I goofed.... And should have known better...
    Now that that's out, I removed both brake masters for rebuild and placed them in a box. I did however, fail to mark them. One is a .75, and the other a .70. I have the same LD19s all around. My car is a VD RF98.
    I know different folks use different configurations. That being said. Which bore TYPICALLY goes of the front????
    Thanks in advance!
    John
    NC
    Liked: 302
    bigger bore = lower pressure, so typically the rear master...
    Tacoma, Washington
    Liked: 210
    Quote Originally Posted by captdigi View Post
    ....I know different folks use different configurations.
    Above is your answer.
    The only reason for different configurations is because some cars run a mix of LD19's and LD20's (which means you use the same size masters ((most of the time ))).
    Others run LD19's or LD20's ALL the way around. Thus, different masters.
    Phoenix, AZ
    Liked: 123
    Default Masters
    Got it. Thanks guys!
