Results 1 to 11 of 11
    delran nj
    Default exhaust headers source
    I need a set of exhaust headers for my 82 van diemen FF1600. I have heard from hy tech and universal racing services. Are there any other sources? I am in Phila/S jersey area
    Senior Member Clyde's Avatar
    New York
    Default Good people
    Try the people at BAT, Peter or Erik @ (941-355-0005) in Florida. They have a good and affordable exhaust system that I believe will fit your racecar and they are supporters of the FRCCA.
    delran nj
    Default bat headers
    nothing in their catalog matches my headers. Headers are beside cyl. head and valve cover,but not above. Completely enclosed by engine cover.
    Sarver, Pa
    Sounds like early Citation headers. I got a spare set. Ooops sorry, mine are for Pinto.
    Liked: 1395
    Try this guy: www.hytechexhaust.com. John builds the best systems.
    Michigan
    Liked: 235
    Default Headers
    I have this set available. They are off an 81 VD but from the pics I've seen they appear to be the same as 82.
    $ 250.00 plus shipping if you are interested.
    Spring Hill Florida
    Default Roxanne's Headers
    Can build you a performance system. Check out www.roxannesheaders.com
    Senior Member Nardi's Avatar
    Southeast
    Liked: 121
    I had JR make a set of stainless headers for a customers Ralt Rt-5. Both the customer and I were pleased with his work.
    New Jersey
    Liked: 20
    I have an excellent set of Swift-style Hytech headers, but they won't clear the factory body.
    Spring Hill Florida
    Default Headers
    Not a problem... I can build a custom set... Need some photos/measurements. The set that you have marked with points of interference also makes fabrication easier. Most of my systems are stepped stainless steel, but your option.
    Santa Fe, NM
    Liked: 25
    Default RF81-RF82
    Gordy's RF81 headers will fit. The rear bodywork on the RF81 and RF82 are identical. Only the rear suspension changed. You will save a bunch of money!
    - Frank C
