Results 1 to 8 of 8
    NH
    Liked: 67
    Default Brake part numbers -new to vee
    What year beetle should I be using when looking for Vee brake parts?
    I'm looking for new wheel cylinders and am confused about the various part numbers I see online
    Lexington KY
    Liked: 50
    '64. Part number for rear cyls is 113-611-055 (19mm). Rears are 113-611-057. (22mm)
    Here are some part numbers and pictures that will help:
    http://www.sracing.com/Store/FV_Stuff/FV_Stuff.htm
    DO NOT ORDER off this page though. I am retired and will not fill the order. You can call for info and possible orders for things that I have left,
    859-252-2349 or
    859-339-7425
    NH
    Liked: 67
    THANK YOU VERY MUCH!
    All those part numbers are going to help me tremendously!
    Lakeside
    Liked: 58
    Default Brake parts
    I think Jim meant FRONTS are (22mm)
    You might also find that some will not carry this number (113) and have replaced it with (131) for the 65 Bug.
    Just be sure to stay away from : Made in China.
    Hope that helps
    Dietmar
    www.quixoteracing.com
    Senior Member Amon's Avatar
    Medina, Ohio
    Liked: 174
    Dietmar is correct about the CHINESE made wheel cyllinders! There cheap, leak even
    when new and the mounting threads will dethread when mounting, so pay a few more dollars for the TRW or genuine German WC's!
    Mark
    88' Citation 002'
    NH
    Liked: 67
    Ut o I had ordered the Dorman ones from rockauto.com...
    Is Dorman the cheap chinese ones your referring to?
    I've read from others on the forums that these cylinders are about $8 a piece however I can't find them for that price.
    Lakeside
    Liked: 58
    Default Brake parts
    Can't comment about what Rock Auto sells.
    Both the TRW and ATE's ( German) can be found through several sources including www.quixoteracing.com. They are 14 for the TRW's and 17 for the ATE's.
    I also believe Jim ( SR RACING) might still have some in stock
    Dietmar
    Vancouver BC
    Liked: 49
    Quote Originally Posted by mikehinkle View Post
    Vee parts have two prices - the ones we use when trying to promote the class, and the ones you actually have to pay when you order them!
