Results 1 to 26 of 26
    Senior Member David Locke's Avatar
    Indiana
    Liked: 175
    Default Helmet requirement
    When will helmets with a 2010 Snell sticker become mandatory?
    hampden ma
    have not seen any proposal so you likely have one or two more years on the 2005. normally the standard is not changed until the new ones are readily available.
    Indiana
    Liked: 175
    Snell 2010 helmets have been readily available for quite some time. The 2015 Snells will start coming out in about 14 months.
    Contributing Member Revs2-12k's Avatar
    Wilmington, NC
    Default Oct 1st 2015
    From the horses mouth... (SNELL).
    http://www.smf.org/standards/sa/2015...leaseNotes.pdf
    Working hard to enhance my Carbon Fiber footprint....
    2011 Stohr F1000
    www.Area81Racing.com
    Indiana
    Liked: 175
    Quote Originally Posted by Revs2-12k View Post
    That's the 2015 sticker. My question is when the SCCA is going to make (at least) a 2010 sticker mandatory, i.e., when will I need to replace my 2005?
    Liked: 600
    My quess is, for club racing 2017.
    They normally do not change the recommended helmet minimum requirements, until new helmets have been available for a year.
    Indiana
    Liked: 175
    Again, I'm not asking about the 2015. I'm asking about the 2010, which has already been available for about three years.
    Wilmington, NC
    Default Testy, Testy
    I was responding to your statement " The 2015 Snells will start coming out in about 14 months." not your question.
    2011 Stohr F1000
    Indiana
    Liked: 175
    IMO, KEA has correctly answered your question, SCCA Club Racing usually requires you to wear a helmet no older than two Snell Ratings back. Hense when the 2015's are finally out, only 2015 and 2010's will be current.
    BTW, I was responding to your statement " The 2015 Snells will start coming out in about 14 months." not your question.
    If that's the case, then the 2010 Snell sticker probably would become mandatory 1/1/2016 (rather than 2017).
    So the 2015s will be available in slightly over 13 months (rather than 14 months).
    Liked: 854
    Default My experience
    My first helmet was a Snell 2000.
    Last SCCA Annual sticker was applied for 2008.
    Logically, if SCCA is consistent, the 2010 should be good to get a 2018 sticker.
    Indiana
    Liked: 175
    I have a 2005 Snell with a 2014 SCCA annual tech sticker.
    Tacoma, Washington
    Liked: 210
    Quote Originally Posted by David Locke View Post
    Well, annual tech stickers are only good for one year
    Indiana
    Liked: 175
    Yes, I know, I've gotten them many times.
    Liked: 600
    Default Helmet
    David,
    Liked: 146
    In other words, a Snell 2005 helmet will still be SCCA compliant through: 2015 for sure, 2016 most likely, 2017 possibly, 2018 unlikely.
    Dale V.
    Lake Effect Motorsports
    FM
    Spartan VP-2/Mazda
    Florida
    2005 helmets will be good until the 2020 sticker comes out.
    From the 2015 rules,
    "All helmets meeting the latest or two immediately preceding Snell Foundation
    standards (SA2015, SA2010, SAH2010, SA2005, SA2000, M2015,
    M2010, M2005, M2000, K2010, K2005, K98)
    hampden ma
    Quote Originally Posted by jbrannon7 View Post
    no that is wrong.
    the 2005 helmets will be good until the GCR is changed. the GCR will be changed when there is an adequate supply of 2015 helmets available. then 2010 and 2015 will be legal.
    Burr Ridge, Illinois
    Liked: 296
    As soon as 2015's are available, buy one.
    Don't go cheap with your personal health & well-being.
    Glenn
    Saint Louis, MO
    Quote Originally Posted by dick patullo View Post
    no that is wrong.
    jbrannon7 is quoting from the Solo rulebook which allows an extra five years of use. For us cone chasers, the currently legal 2000 Snell helmets must be replaced when the 2015 spec is released. There is no grace period like the club racers get. After all, we have already gotten 15 years of use out of the ratty old helmets.
    Houston, TX
    Liked: 68
    Why? Is there any significant spec difference over time, or are you suggesting that regular replacement is a good idea?
    Marshall Mauney
    Milwaukee Region
    Indiana
    Liked: 175
    Glenn
    Quote Originally Posted by Marshall Mauney View Post
    Detroit area
    Liked: 141
    delete
    Indiana
    Liked: 175
    That is badly worded. It is talking about the 2015 standards then says 2010 and 2005 are currently legal. They may be currently legal but in two weeks' time when the 2015s are available that will presumably change. They should have had a lawyer proof read it.
    Bear in mind that the Snell Foundation finalized the SA2015 standard in October 2014. The link I posted is to a press release from that time frame.
    Detroit area
    Liked: 141
    Ah - thank you David - seems bad to me that it was undated. Since you just posted it I assumed it was recent.
    Liked: 296
    In regards to this thread, my suggestion is -
    When the 2015 SA's come out, why buy a 2010 ? If you have to update, update to the latest & safest (assuming).
    Glenn
    Dave, thanks for the Snell post.
    Banned Modo's Avatar
    DC Area
    Liked: 19
    Don't egg'em on buckaroo, a 2010/2015 ain't gonna save ur butt any more than a 2005, JMO
