Results 1 to 9 of 9
    Senior Member Jasonrmbell's Avatar
    Florida
    Default Stohr Geartronics Install
    Jason Bell
    STOHR 2013
    F1000
    f1000bwracing@highwaysystemsinc.com
    Alpine California
    Liked: 273
    Be careful packaging that compressor too tightly, they have a tendency to overheat and shut down. Same goes for the solenoid block.
    Scat ducting helps
    Gary Hickman
    Edge Engineering Inc
    FB #76
    Member johnspranger's Avatar
    Colorado
    Jason did you give up on the Proshift?
    Vancouver, Canada
    If you run these compressors over 70 deg C / 160F in temperature they have an internal thermal shutdown by design. John on his new phoenix had his mounted in the side pod behind his radiator and experienced that. Which in hindsight is not the best place for it as he admitted.
    Since you can run any length from the compressor to the accumulator tank, you have an entire car for mounting options ! to keep the compressor away from regular 70 deg C + temperatures
    You can ultimately remove the thermal shutoff switch, which from testing has the compressor run up to 90C still without any sign of deterioration. compressor manufacturer likes to see 70C max.
    Valve blocks can run in temperatures around 80/90 C MAX reliably. Geartronics does make a pro spec valve block rated for temperatures upwards of 200C if you are right near say a turbo manifold
    Nicholas Belling
    email@nicholasbelling.com
    Florida
    I didn't give up on the pro shifter but after driving the citation I bought with the geartronics installed the pro shifter had to go. I can't wait to race the geartronics. That's what I can say.
    Jason Bell
    STOHR 2013
    F1000
    Florida
    I believe were we have it mounted will not experience these type of temps. Mainly in the rear diff carrier. Should stay cool. At least I hope.
    Jason Bell
    STOHR 2013
    F1000
    Baltimore, MD
    Liked: 14
    Did mounting the compressor in the drive box work out OK?
    Any overheating issues ?
    Huntsville, AL
    Quote Originally Posted by Gary Slahor View Post
    Not a Stohr, but mounting the compressor in the drive box worked very well on the Citation.
    Florida
    Yes I have that installed that way in both my citations. Works great.
    Jason Bell
    STOHR 2013
    F1000
