Results 1 to 9 of 9
    Senior Member bkd320's Avatar
    Evans City, PA
    Liked: 26
    1997 Star Formula Mazda chassis 97-085, it has been a meticulously maintained, very clean, very fast, competitive car. No major incidents. The car underwent a complete frame up rebuild over the winter of 2011. This was Lucian Pancea's car that took 4th at the runoffs. It has 3 logbooks including the current one with a ton of good race history and no major incidents.
    New Body and Fresh paint - 5 races
    -New Engine with 3 races (NOT Drummond sealed)
    -Taylor blueprinted gearbox with 3 Races
    -Car cover
    -Alignment Bars
    -Wired for radios
    -New fuel cell 2011
    -New OMP Belts 2011
    -Aluminum calipers and spare set of Steel Calipers
    -New rod ends 2010
    -Dbl adj. Koni shocks
    -New wheel bearings
    -New CV joints
    -Steering rack rebuilt over winter
    -Carb rebuilt over winter of 2011
    -the list goes on....
    -Huge list of spare parts-
    FM Parts list and prices
    1 spare front uprights - NEW ($275ea) = $275
    1 spare front hubs - NEW ($260ea) = $260
    1 spare lower control arm -NEW ($130ea)= $130
    1 spare upper control arm rocker - NEW ($360ea)=$360
    1 spare front anti-roll bar - NEW ($75ea)= $ 75
    1 spare rear upright - NEW($310ea) = $310
    1 spare rear hub - NEW ($372ea)= $372
    1 rear lower control arm - NEW ($130ea)= $130
    2 aluminum belly pans 1 NEW/1 USED($175ea)= $262
    1 rear aluminum belly pan USED ($100ea@50%)= $ 50
    1 stainless steel belly pan USED ($260ea@50%)= $260
    3 spare master cylinders NEW ($115ea)= $345
    2 SS brake lines NEW ($50ea)= $100
    4 spare brake rotors NEW ($130ea)= $520
    4 Misc T-bolt clamps NEW ($10ea)= $ 40
    2 spare mufflers USED ($315ea@ 50%) = $315
    Supertrapp end cap & plates
    2 full sets of jets NEW ($80) $ 80
    1 SS fuel line NEW ($50)= $ 50
    3 adjustable rev chips USED ($40ea@50%) = $ 60
    2 spare mirrors NEW ($70ea) = $140
    2 spare noses, 1 complete (600+360+120)= $1080 (price adjusted for condition each)
    1 spare front cowling USED ($470@60%) = $282
    3 spare sidepods USED ($475@60%)= $855
    1 spare engine cover USED ($470@60%)= $282
    1 complete spare rear wing NEW ($580)= $580
    1 spare rear wing mount plate NEW($160)= $160
    Complete set of hyme joints NEW ($500)= $500
    Formula Mazda car cover USED($480)= $480 (no discount here, it's replacement value, if you can find one)
    Alignment bars ($200)= $200
    Misc zeus clips etc others ($100) $100
    UPDATE: NEWLY SOURCED USED (but clean) SILVER WHEELS W/ Goodyear Rubber in good shape! = $1250
    Total in spares= $9903
    -Never bent
    -Current logbook and annual
    Additionally - with the car I am selling my VERY extensive inventory of FM parts as follows:
    For photo's of parts detailed below and more pics of the car itself, click on the link below:
    http://s945.photobucket.com/user/bkd320/slideshow/
    If you want to see the car in action (prior owner), here are 2 YouTube video's:
    http://www.youtube.com/watch?v=5YVt0wgfrKM
    http://www.youtube.com/watch?v=HV6PTUTMSFU
    Part # Description Qty List Price Total
    Front Suspension:
    000-020m 5/8 Front Anit-Roll Bar Collar Kit (2) 13 @ $15.70 ea. = $ 204.10
    000-111 Am Front Upper Comp. Spacer Kit 2 @ $13.04 ea. = $ 26.08
    000-111 Sm Rocker Upper Misalignment Sp 2 @ $13.04 ea. = $ 26.08
    000-112 Front Hub 2 @ $258.06 ea. = $ 516.12
    000-113 Hub Bearing Spacer 2 @ $78.14 ea. = $ 156.28
    000-121m 7/16 Tapered Spacer Kit (8 per) 1 @ $13.76 ea. = $ 13.76
    000-122 Rocker-unpainted (left) 1 @ $358.18 ea. = $ 358.18
    000-123 Rocker Pivot Shaft 1 @ $38.50 ea. = $ 38.50
    000-124 Rocker-unpainted (right) 1 @ $358.18 ea. = $ 358.18
    000-136 Rocker Stud 1 @ $27.90 ea. = $ 27.90
    000-149(132) Front Anti-Roll Bar Drop Link 1 @ $29.61 ea. = $ 29.61
    000-139 5/8 Front Roll Bar 1 @ $77.62 ea. = $ 77.62
    000-140 5/8 Front Anit-Roll Bar Mount 2 @ $39.08 ea. = $ 78.16
    Steering:
    010-101 Steering Rack 1 @ $551.67 ea. = $ 551.67
    010-102 Steering Rack Mount 2 @ $36.12 ea. = $ 72.24
    010-103 Clevis End 2 @ $58.08 ea. = $ 116.16
    010-112 Steering Column Guide 1 @ $21.65 ea. = $ 21.65
    010-113 Splined Adaptor 2 @ $81.82 ea. = $ 163.64
    Rear Suspension:
    020-030m 3/4 Rear Anti-Roll Bar Collar Kit 4 @ $19.48 ea. = $ 77.92
    020-103 Uprights (complete) 1 @ $1145.39 ea. = $1,145.39
    *Upright (020-103)
    *Rear Drive Axle (020-108)
    *Rear Hub (020-109)
    020-103 Uprights (complete-USED 50%) 2 @ $572.70 ea. = $ 1,145.40
    *Upright (020-103)
    *Rear Hub (020-109)
    020-104 Rear Upper Comp Spacer 2 @ $20.02 ea. = $ 40.04
    020-105 Rear Lower Shock Mount-LH 1 @ $92.66 ea. = $ 92.66
    020-106 Rear Lower Shock Mount-RH 1 @ $92.66 ea. = $ 92.66
    020-107m Camber Hime Spacer (2per) 2 @ $15.88 ea. = $ 31.76
    020-110 Rear Lower Control Arm 2 @ $127.85 ea. = $ 255.70
    020-112 Rear Toe Link-6.5" (complete w/himes) 4 @ $124.41 ea. = $ 497.64
    *(1) 7/16 x 7/16 RH Suspension Hime
    *(1) 7/16 x 7/16 LH Suspension Hime
    020-113 Radius Rod 2 @ $51.48 ea. = $ 102.96
    020-118 11/16 Rear Anti-Roll Bar Mount 2 @ $39.08 ea. = $ 78.16
    020-119 Rear Anti-Roll Bar Drop Link 2 @ $31.57 ea. = $ 63.14
    020-120 11/16 Rear Anti-Roll Bar Slider 2 @ $42.33 ea. = $ 84.66
    020-121 Rear Anti-Roll Bar Lower Mount 2 @ $12.17 ea. = $ 24.34
    020-128 Radius Rod Clevis 2 @ $29.46 ea. = $ 58.92
    Chassis:
    030-107 Firewall Upper 1 @ $62.92 ea. = $ 62.92
    030-108 Firewall Lower 1 @ $62.92 ea. = $ 62.92
    030-109 Radiator Fairing - Left 1 @ $51.48 ea. = $ 51.48
    030-110 Radiator Fairing - Right 1 @ $51.48 ea. = $ 51.48
    030-116 Shear Plate #3 (bi-bevel) same 7 @ $35.46 ea. = $ 248.22
    030-116B Shear Plate #3 (bi-bevel) same
    030-117 Shear Plate #4 2 @ $29.40 ea. = $ 58.80
    030-118 Shear Plate #5 8 @ $19.15 ea. = $ 153.20
    030-119 Shear Plate #6 5 @ $22.23 ea. = $ 111.15
    030-123 Shear Plate Spacer 16 @ $8.06 ea. = $ 128.96
    030-125U Engine Spider (used-50%) 1 @ $124.82 ea. = $ 124.82
    030-126m Urethane Bushing/Sleeve Kit 2 @ $20.10 ea. = $ 40.20
    030-128 Front Brake Bulkhead 1 @ $135.66 ea. = $ 135.66
    Brakes:
    040-105 Brake Caliper Rebuild Kits 5 @ $18.87 ea. = $ 94.35
    040-108 Master Cylinder 3/4-Wilwood 3 @ $88.22 ea. = $ 264.66
    Brake Caliper (used cast) 4 @ $75.00 ea. = $ 300.00
    Brake Caliper (used cast-loaded w/PFC's) 4 @ $125.00 ea. = $ 500.00
    Engine:
    050-110 Weber Carburetor (used-50%) 2 @ $224.97 ea. = $ 449.94
    050-113 Air Filter Canister 1 @ $98.68 ea. = $ 98.68
    050-114 K&N Filter Canister 1 @ $54.97 ea. = $ 54.97
    050-115 Gasket - Lower Intake Manifold 1 @ $8.77 ea. = $ 8.77
    050-129 Gasket - Wtr Pump/Engine Frt 1 @ $10.91 ea. = $ 10.91
    050-133 Header 1 @ $397.75 ea. = $ 397.75
    050-134 Flow Master Muffler (325508) 1 @ $300.00 ea. = $ 300.00
    050-137 Velocity Stack (used-50%) 4 @ $26.46 ea. = $ 105.84
    050-146 Oil Pressure/Temp Adapter Blk 1 @ $69.47 ea. = $ 69.47
    050-157 Vacuum Tube Assembly 1 @ $54.04 ea. = $ 54.04
    050-167 42mm Choke (used-50%) 6 @ $27.11 ea. = $ 162.66
    46mm Choke (used-50%) 63 @ $27.11 ea. = $1,707.93
    Transmission:
    060-101 Bellhousing Adaptor 1 @ $459.89 ea. = $ 459.89
    060-101 Bellhousing Adaptor (used-50%) 1 @ $229.95 ea. = $ 229.95
    060-102 Flywheel 1 @ $390.40 ea. = $ 390.40
    060-103? Clutch Disc (not sure on legality) 1 @ $54.00 ea. = $ 54.00
    060-104 Clutch Pressure Plate 1 @ $168.00 ea. = $ 168.00
    060-128 CV Joint 4 @ $70.49 ea. = $ 281.96
    060-130++ 1/2 Shaft (complete) 1 @ $310.38 ea. = $ 310.38
    *(1) 1/2 Shaft (060-130)
    *(2) CV Joint (060-128)
    *(2) CV Boot (060-129)
    060-130++ 1/2 Shaft (complete-USED 50%) 2 @ $155.19 ea. = $ 310.38
    060-131 CV Spacer 2 @ $45.76 ea. = $ 91.52
    Ignition:
    080-102 Battery Box (needs some adj.) 1 @ $134.41 ea. = $ 134.41
    080-116 MSD Spark Box (used-50%) 1 @ $152.95 ea. = $ 152.95
    080-120+ Alternator (w/upgraded pulley) 1 @ $328.69 ea. = $ 328.69
    080-121 Alternator Belt 2 @ $15.92 ea. = $ 31.84
    Ignition Coil MSD (used-50%) 2 @ $28.76 ea. = $ 57.52
    080-131 Starter 2 @ $163.48 ea. = $ 326.96
    Data:
    Autometer RPM 1 @ $111.95 ea. = $ 111.95
    Autometer Water Temp 1 @ $71.95 ea. = $ 71.95
    Autometer Oil Pressure (used-50%) 1 @ $26.96 ea. = $ 26.96
    Cooling:
    100-101m Radiators 1 @ $155.99 ea. = $ 155.99
    100-113 Swirl Pot 1 @ $216.00 ea. = $ 216.00
    100-113U Swirl Pot (used) 1 @ $97.79 ea. = $ 97.79
    100-116 Long Water Pipe 1 @ $72.36 ea. = $ 72.36
    100-117U Intermediate Water Pipe (used-50%) 1 @ $32.57 ea. = $ 32.57
    100-121 Thermostat Gasket 1 @ $4.86 ea. = $ 4.86
    100-125 Oil Cooler 1 @ $362.66 ea. = $ 362.66
    100-126 Oil Cooler Bracket 1 @ $127.42 ea. = $ 127.42
    100-125/126 Oil Cooler and Bracket (used-50%) 1 @ $245.09 ea. = $ 245.09
    100-132 Oil Injector Line - Green 1 @ $21.92 ea. = $ 21.92
    100-133 Oil Injector Line - Blue 1 @ $21.92 ea. = $ 21.92
    100-134 Oil Injector Line - Yellow 1 @ $21.92 ea. = $ 21.92
    100-135 Oil Injector Line - White 1 @ $21.92 ea. = $ 21.92
    Himes + Bearings:
    120-101 1/2 x 1/2 Camber Hime 1 @ $67.65 ea. = $ 67.65
    120-106m 3/8 x 3/8 LH Hime Steering 1 @ $39.32 ea. = $ 39.32
    120-109m 5/16 x 5/16 RH Hime RARB 2 @ $7.89 ea. = $ 15.78
    120-110m 5/16 x 5/16 LH Hime RARB 2 @ $7.89 ea. = $ 15.78
    120-117 Wheel Bearing 4 @ $55.71 ea. = $ 222.84
    120-118 Rocker Bearing 2 @ $12.96 ea. = $ 25.92
    Engine and Gearbox:
    Rebuilt Engine (complete-intake & exhaust) 1 @ $3000.00 ea. = $ 3000.00
    *rebuilt motor IS NOT a DRUMMOND SEALED MOTOR - just learned that on Friday 12/6/2013 when I spoke directly with Daryl Drummond.
    Core Engine 1 @ $1350.00 ea. = $ 1,350.00
    Total $21,116.48
    All prices from- formula mazda parts
    IF IT IS NOT NOTED AS USED, IT IS NEW!
    Finally - if you have watched previous threads, this car was listed and due to an idiot that proclaimed his greatness through assessing value as he saw it, I have had that thread removed and am starting anew.
    That said, the price is now below where I originally listed, and the car and ALL parts detailed herein can be yours for $34,500 (or REASONABLE OFFERS - which are NOT in the $22k to $24k range).
    If you are interested in my car and all that goes with it, please email me directly at:
    bditson@zoominternet.net
    or call me at:
    724.766.2178
    DO NOT TENDER AN OFFER IN ANY WAY THROUGH THIS THREAD, I WILL NOT RESPOND!
    Thank You!
    Here are some photo's, but the REAL detailed photo's of EVERYTHING are on the photo bucket link in the initial advertisement.
    Austin
    If this is still available in a month's time, I will seriously consider this.
    Evans City, PA
    Liked: 26
    Default bit of an update....
    this is bump #1 just to refresh.
    Today's effort will include the install of a brand new rigt side pod already painted to match!
    Also, I didn't mention that earlier this fall the car got a new gel cell battery and a clean and repaint of the battery mount.
    Please let me know if there is more that I can answer, this is a great deal when you consider that there is a n FM on ebay with practically no spares and they are looking for $25,000.
    I am holding to my ask of $34,500/obo, but there is wiggle room and I am getting motivated due to other intersts.
    Evans City, PA
    Liked: 26
    Default Price reduction......
    She needs some interest as there are other things going on!
    Price now....$30,000 or reasonable offer. Shoot me an email.
    Evans City, PA
    Liked: 26
    Default bottom dollar post.....she's gotta go!
    ok all......she's gotta move on to a new home.
    Have another car (maybe 2) and I want to move it on!
    Send an email...bditson@zoominternet.net, or a call/text at 724.766.2178.
    $29,000 firm
    Member Aeroyacht's Avatar
    Long Island, NY
    Default Bellhousing adaptor
    Do you still have the used bellhousing adabtor for sale ?
    I need one for my Lola T440.
    You can email me directly (gt at aeroyacht dot com)
    Gregor
    Evans City, PA
    Liked: 26
    Default Sale pending....
    May be going to a new home.....when deposit check arrives she is claimed!
    Evans City, PA
    Liked: 26
    Default Sold!!!
    Sold and headed to its new home in Arizona!
    Thank you ApexSpeed!
    Glendale, Arizona
    Liked: 501
