Results 1 to 28 of 28
Thread: Long bolts
    Albany, NY
    Liked: 233
    Default Long bolts
    Hi folks,
    I am in need of a long bolt ... 7/16-20 x 9, grade 8, hex. Have tried just about every business that is online. Closest I came was Fastenal which actually had a listing but no stock. Seems like I might have to get one made by a machine shop for big bucks.
    Any ideas?
    Somerset, Kentucky
    Liked: 126
    Liked: 1461
    racebolt has 'em up to 8.5" I bet aircraft spruce of coast fab can source just about any An size even if not in the catalog.
    Liked: 1845
    Fastenal
    Fastenal Part No. (SKU): 18898
    AHave them check their stock nationally, not just local.
    Albany, NY
    Liked: 233
    Thanks guys. Those businesses were checked. National office for Fastenal said they could make new ones but I'd have to order 100 of them (at about $7 per). There's one Fastenal in the northeast that had 2 of them but they refused to give them up.
    Rob, these bolts will go through the bottom of the upright and can't have thread.
    Thanks for all the ideas. I'll try some of the suppliers for whom I only checked their catalogs and see if they can source them.
    atlanta, ga
    Liked: 136
    Why exactly can you just not purchase them from the Fastenal location that has 2 in stock?
    Albany, NY
    Liked: 233
    Ya know Glenn, that's a great question. But I figured that if my local Fastenal couldn't get them to send them here, then they just didn't want to part with them. But why the heck not? After all, they're not keeping them to just look at them. They want to sell them. I'll see if they're open tomorrow.
    P.S. Those two did not show up on the National catalog so somethings going on. Thanks for pointing out the obvious to me though. I am often quite thick.
    Sequim, WA
    Liked: 46
    Post
    Recommend you give Fast Forward, Monterey, CA a call.
    Maple valley, wa
    Default bolt
    ARP. They have studs that will work. Good luck
    Senior Member johnd's Avatar
    Wallingford, CT
    Liked: 36
    Jim:
    How about a rod and have the rod cut to the length you would need. Then have the two ends threaded (die) to suit? This will keep the threads away from the upright.
    Just a note about having a bolt machined. The grain flow on fasteners is critical especially in the area of transitions (such as around the shank to the head). If cut, this will result in a weak spot. Also, without a proper fillet roll under the head, the fatigue life will also be reduced.
    I think that a long stud, with nuts on the ends might be a valid and economical solution.
    John D.
    Jupiter, Florida
    Liked: 79
    An AN7-80 is the longest 7/16-20 in that series and gets you to 8-3/32 grip length. Will that do ya?
    I would not have 100% confidence in a grade 8 bolt in a suspension application. Who knows where they come from nowadays.
    If Fast Forward can help you out as somebody suggested above-I would go with them.
    Lincoln NE
    Liked: 82
    Default bolts
    check your caterpillar dealer they have a lot of large bolts in strange sizes--that's where I got some to upgrade the case bolts in my aircooled supervene
    Liked: 123
    Get some 7/16" StressProof bar (it's a trade name product but widely available), cut threads on the ends. The shear loaded portion will be un-threaded and quite strong - StressProof is 115Kpsi and is designed for making fasteners out of so it machines very well. The tension load requirement is probably quite low in that application, and 7/16" is a fairly hefty fastener for the bottom of an A-arm anyway so a little overkill.
    StressProof is also available in hex bar for people who need to make up special lug nuts and such. It is not heat-treated after machining.
    Albany, NY
    Liked: 233
    Thank you for the continuing good suggestions guys.
    Albany, NY
    Liked: 233
    Well this is interesting ... I just looked at a half dozen websites for Stressproof rod. The only supplier that listed it in 7/16 showed it as "or equivalent". The others had 1/4, 3/8, then skipped to 1/2 ...
    Liked: 3206
    Rob, these bolts will go through the bottom of the upright and can't have thread...
    So yours have been upgraded from 3/8-24 to 7/16-20? IIRC, the through bolts at the bottom of the rear upright when I had them were 3/8-24.
    SoCal
    Liked: 102
    Another material option for custom studs is ETD150. The acronym stands for Elevated Temperature Drawn, and the tensile strength is 150,000 psi. I have used it for zillions of studs because it's a high strength alloy in its as-supplied state that has enough ductility for really nice thread rolling.
    Banned Modo's Avatar
    DC Area
    Liked: 19
    That's a kit car make your own deal, make and thread to size (weld one nut may be option), I would get an american made die, about $20 at msc or McMaster and use some 7/16'ths stock, can then put the threads only were you want them, can use mild steel cheapest, go to 4130 next, and 4340 but maybe hard to thread, (or have one threaded at a machine shop) ....... made one for a 83 reynard, it is no biggie to make bullet proof, look at most of the Reynard, "mild steel" I even fusion welded oxy-acet for the first time the retaining tube onto the.060 fabricated upright ...... don't ask me how I drilled that buggar out on the lathe ,,,,, yikes!! no youtube for gundrilling tips ....... good luck!! ....
    think I used 4130 round just for a little extra strength for the bolt threads ...
    heck, one of these guys have some 7/16th stock, send him some specs
    Liked: 124
    How about 7/16 x 14? I needed some 1/2 x 9 inch, fine thread was harder to get than coarse. If you thread your own get an adjustable die and make a few passes to get down to size. You may need a longer bolt to get the shank long enough to pick up your shear loads.
    San Jose
    Liked: 83
    I buy them at my local Caterpillar dealer...
    Albany, NY
    Liked: 233
    Dave, I no longer have the Citation. This is for a Cheetah.
    Liked: 3206
    AHAH...
    No wonder they are different. Good luck finding them.
    San Jose
    Liked: 83
    Yes for the rear lower bolt through the upright. I have a suggestion or 2 about that bolt that makes it easier to change springs.
    Arkend@sbcglobal.net
  24. #24
    Banned
    Liked: 1116
    I had some custom fasteners made by Lawrence Hayes (HayesCages on this site) years ago for my FV front beam. Just supplied drawings....Perfect...
  25. #25
    Liked: 1461
    The caterpillar suggestions are excellent. My dad worked for the dealer in Indy and we used to take discarded track bolts, grind 'em to a point, and use them as tent stakes on winter camp outs. I still have a bunch of cat stuff around the shop that came from his stash and I've never been able to buggar one.
  26. #26
    Sydney, Australia
    Liked: 146
    Will a 2L-4523 Hex Head Bolts from Caterpillar work?
  27. #27
    Raleigh, NC
    Quote Originally Posted by Hawke View Post
    This one has specs but no price
    https://commerce.cat.com/en/catcorp/bolts/2L-4523
    This one has price but no specs.
    http://www.finditparts.com/t/190/man...rpillar-2l4523
    $11.67
  28. #28
    Albany, NY
    Liked: 233
    Dick, that bolt looks good. But I can't tell what material it is. I'll just call them. Thanks.
    Thanks to everyone.
