Results 1 to 8 of 8
    delran nj
    Default intake manifold water passage block
    What is the best way to seal off the intake manifold water inlet from the cylinder head/
    Maineville
    Liked: 103
    Default Soda Cans are your friends
    I've seen a rectangular cutout from a soda can silicone in place on a number of intakes.
    Liked: 601
    Default intake manifold block
    Put a little filler inside the passage, then epoxy over, making sure it doesn't protrude past the surface.
    delran nj
    Default block the cylinder head?
    Would it be better to block the passage in the cylinder head? I suspect water is leaking past the gasket. I see water from the center intake manifold bolt.
    Liked: 3278
    Quote Originally Posted by rich s View Post
    IMO, while GCR says the water passage in the intake manifold may be plugged, there is no mention that one can do the same in the head. If something isn't specifically allowed, it is usually not permitted.
    Liked: 3278
    Default Fixing the leak...
    Also, if it leaking around the bolt, just put some RTV on the bolt threads when you assemble the manifold to the head. IRRC, the bolt goes all the way through into the water passage, so it needs to be sealed.
    Senior Member racersonly's Avatar
    Oshkosh,WI
    Liked: 95
    I just recently discovered that Pegasus sells a specially made intake gasket without the water hole. You still need to seal the bolt threads.
    Jack Bartelt
    Lola T540 CFF
    Liked: 601
    The rules at one time, required "spec" gaskets to be used and intake to head was one.
    Don't know if that has changed.
