ummmm this is for NWFC.
Emphasis on the FC part and we don't really run SCCA that much either.
Joe,
These tests and equalizing are NOT being done by the SCCA. Rather, ICSCC drivers in the Northwest under 'mutual agreement' of the competitors who want good competition. Even the Zetec drivers support it.
I'm not sure any FF's drivers here in the Northwest have even converted to Fit's??
Not only do the zetec drivers support it, they were the ones who pushed for equalization.
Update: from the just released nwfc newsletter
Zetec ......... testing was conducted on Sept. 24th at Spokane County Raceway. Initial concerns were confirmed, as the Zetec was able to run fairly effortlessly times on par or less than its pinto powered counterpart....................................... ........................... Data system was not working on the car at time of this publishing, and only a handful of stopwatch times were able to be taken. Weight was not able to be added to the car other than through fuel at time of testing (approximately 40lbs difference). At full fuel, car was roughly on par with what previous pinto’s have been capable of. However, due to a lack of data collected and scientific process not being followed for this informal test day, as well as the car not being able to be pushed to its limits as safety and emergency crews were not on hand, this test should only be taken at face value and more testing will be conducted in the spring. Until testing can result in conclusive data no official rule change will be brought to sanctioning bodies, however those who do own Zetecs currently will handicap their cars at NWFC events until an official rule change is agreed upon. More on this in 2015.(Current idea is around 40 lbs of extra ballast for Zetecs)
.....'s show where possible confidential information was at for driver of said zetec, and I don't' want to let the cat out of the bag before the runoffs. Additionally, both pinto and zetec drivers were on hand to witness the testing.
But zetec drivers are in for a 40 lb weight penalty to start the season, and adjust after further testing can be completed at the Spokane test and tune next year. For the record this means one of the cars will be adding 80 lbs of total ballast. The lead has already been poured.
Just a question. How does one safely add 80#'s of lead ? I'm in the opposite situation. However, when my son begins driving the Reynard, I may need to add some ballast. TIA
They refer to info that the driver of said car may not want released publicly before the runoffs as they could give away possible competitive secrets. First ......'s can be safely assumed using some Google fu. Second ones give away a severe limiting factor of the test and the lap times performed. Based on the test, I think the driver may have a chance to be the dark horse at this year's runoffs with a bit of luck, but they would never tell you that.
Melting down led and molding it to spaces it fits in the frame then Securing it properly. I'm not the one who did the process and info is to me by at least second hand, I'm sure someone else could answer it better.
Google-fu .....'s liiterally returns Sprint Corp'n stockchart....
This is like doing matryoshka dolls in reverse; the more I ask, the further I get away from clear understanding.
I know I need a nap, as I was up until 4am today. And I have missed some of this threads recent updates.
There has to be a reason, right Professor?
"You GO Now"
Rick
As a 140# guy and a Zetec owner/driver, we have melted lead into these sections and there is no chance you will get 80# in there. I have each one filled, steel floor and some other lead in places and still barely make weight at the pro 1210. 1200 in club is easier but I still have all of those areas you note filled with melted lead shot.
-Nick
Pouring lead is easy, especially when you have someone else do it:
Call a gun shop and ask who casts their own bullets in your area (they're out there...).
Contact them and ask if they could do it ("Yes").
Tell them they can use "soft" lead (there is a difference and they will not want to use their good stuff for ballast weights)
Or: Craigslist lead; I found a lot of lead for $1 a lb.
Make a sheet metal mold shaped to fit in between the lower frame members, under your seat if possible.
Take mold(s) to bullet guy and have him pour lead into them.
Pick up your custom lead ballasts later that week.
Bolt them to the floor pan.
Lawrence Hayes
Hayes Cages, LLC
Sagle, ID.
I think AP calipers are made from depleted uranium......you can also fill the pistons with lead
There are pros and cons to pouring your own lead. Personally, I won't do it.
Lawrence Hayes
Hayes Cages, LLC
Sagle, ID.
I remember when plumbers melted lead for cast iron pipes FYI. Water & molten lead do not mix.
Asbestos is kinda old school. Now-a-days we sniff carbon fiber dust...
After stick welding for 10 years prior to the release of MSDS papers I think I've inhaled enough toxic stuff.
Lawrence Hayes
Hayes Cages, LLC
Sagle, ID.
Had plenty of the bad stuff too. Hard to believe I'm still living and the only health problems I've had so far at age 71 were self induced (from smoking).
Big one happened in 2010 right after the big SOVREN weekend and I'm still going 4 years later. Although, in many ways I wish I wasn't. Once you reach a certain point of debilitation it's better to just move on.
