    Senior Member Numbskull XIV's Avatar
    Bradenton, FL
    Liked: 14
    For Sale 1986 Red Devil F440 F-Mod
    I have finally decided its time to sell this car. I'm looking to switch gears and go Road Racing in a winged car and do not have the time or space to keep this car. This car has a lot of potential in the hands of a better driver than me. It would also be a good candidate for a Rotax conversion or a MC F600 conversion.
    History of the Car as I know it:
    This was Jeff Colegrove's 2010 National car and had many great results at national events with this car. They sold it to Dominic Stone in Oregon at the end of 2010 or the beginning of 2011. Dominic ran it locally in 2011 and some in 2012. The car sat from April 2012 to when I bought the car in December of 2012.
    Specs:
    Wheelbase under 73" which means it has a 25lbs less weight minimum
    Track width under 55"
    Weight is less than 725lb minimum with 165lb driver
    4-link rear
    Diffusser with new supports in 2014
    Frame:
    frame front of the front roll bar was reworked back to how it originally was designed (I believe the Colegrove's changed it to allow huge feet)
    Frame from front hoop forward was completely sanded and repainted in 2014
    Suspension:
    Front: Unequal length non-parallel dual wishbone suspension with QRE damper pucks, anti-ackerman steering
    Rear: Dual Novak designed and fabricated trailing links w/ bell crank and pull based dampers, QRE pucks. Aluminum watts link with adjustable pickup point (roll center)
    (entire front suspension was powder-coated in 2014)
    Steering:
    MOMO steering wheel with quick disconnect (new quick disconnect in 2013)
    KOSO digital EGT meter/dash mounted to steering wheel with RPM, Water Temp, and 2 fast response egt's (new 2013)
    Steering rack was reconfigured to be able to fit a 6'3" driver and a 5'1" co-driver
    Steering rack was disassembled and re-greased (2013)
    (Powder-coated tie-rods, painted steering shaft in 2014)
    New powder-coated dash with all new switches in 2013
    Tires:
    19.5” Hoosier R25B’s (1 set on car, 1 set mentioned below, spare set not mounted but used, and 1 set of 18" R25B's used for 2012 National Championships
    That's a total of 4 sets of tires
    Wheels:
    Douglas 10” x 6”, 7” (spare set of wheels with mounted 19.5's)
    Engine:
    Kawasaki 440 electric start w/ dual Aaen tuned pipes (fresh 7/2010) (silencers repacked in 2013)
    Mikuni VM-38 Carbs (one with enrichener) with screens over the intakes
    40 pilot jet in there now (a little too rich on idle, I would put in a 37.5 or a 35)
    220 main jet
    Primary Clutch: Polaris P-85
    Secondary: Arctic Cat Roller
    135-140psi compression
    K&N air filters not on carbs for increased airflow
    Drive:
    #530 chain (New 2010)
    Front sprockets: 11 & 13 tooth hardened steel (one new 2010)
    Rear sprocket: Rebel Gears aluminum 55 tooth, billet aluminum sprocket hub (New 2010)
    NTN Free spin bearings on rear axle (New 5/2010)
    Fuel:
    Pump: Mikuni mechanical and Facet Electronic pump (New 2014)
    Tank: Tig welded aluminum 5qt tank mounted under driver's seat
    Aluminum Pull-start handle (New 2014 with spare pull-start recoil)
    All New fuel lines in 2014
    Brakes:
    Brake Calipers: Wilwood Aluminum Dynalite two piston calipers (two front, one rear)
    Brake Rotors: 7.5” Solid front (2), 10.5” Wilwood cross drilled rear (1) with custom made brake hub
    Brake Pedal: Wilwood aluminum dual master cylinder assembly with bias bar
    Brake Master Cylinders: Wilwood Aluminum MC’s with integral reservoirs (New rear master cylinder 2014)
    Added a brake bias adjuster in 2013
    Cooling:
    dual aluminum 2” core radiators (Honda) with fans and electric water pump (for cooling off in grid)
    Radiators mounted in series for increased cooling (never needed to use fans in grid with 2 drivers)
    Radiators were moved forward for better weight balance
    Thin walled aluminum piping (New 1013)
    Wiring:
    Odyssey Motorcycle battery (New 2013 with good spare battery)
    Kill Switch (New 2013) wired correctly (long story but I can elaborate)
    Aux battery connection
    Wired for plug in Battery Tender
    All new switches in 2013
    Pedals:
    Custom welded pedals (new 2013) with quick pin connect pedal extensions
    (Powder-coated in 2014)
    Misc:
    Chassis setup notes / guide
    Clutching / gearing excel spreadsheet
    Mikuni carb manuals/CD
    Other Mikuni manuals
    Custom made foam seat and insert for my 5'1" co-driver
    Accommodates drivers up to 6’3, currently set up for taller drivers but easily able to accommodate smaller drivers (I have a 5'1" co-driver)
    Impact Racing 6 pt harness
    Several specialty tools
    Spares:
    4 Lightly used pistons
    Engine Gasket sets
    2 water pumps
    Spare Polaris P-85 Clutch (works fine, but could use rebuild)
    51 degree Arctic Cat helix
    whole spare Mikuni VM38 carb
    a lot of spare pilot and main jets
    Extra needles and throttle valves
    New Spare ignition coil and 3 spare used coils
    2 spare stators
    2 spare mechanical fuel pumps
    1 spare Facet fuel pump (disassembled)
    Tons of bolts, nuts, washers, and AN washers
    Rivets and other specialty fasteners
    Spare Rod Ends
    Spark plugs
    Spare recoil starter as mentioned above
    Exhaust silencer packing material
    New bent rollbar that I was going to add to make the rollbar 5-6" taller
    Misc wiring
    all the mechanical gauges that were removed when the KOSO digital dash was put in
    Spare EGT sensor
    Pedals that came in the car
    2 spare belts (unknown if they are new or used)
    New steering wheel with used quick disconnect
    Spare brake hoses
    used spare rear master cylinder
    Radiator plumbing/ tubing
    Spare white rubber pucks
    Spare suspension bits
    Spare bearings
    Tons of hose clamps
    Spare hub
    + a lot more spares I can't think of.
    Trailer: 5' x 8' open trailer bought a month ago with ramps and tie downs.
    Titled and registered in PA
    ASKING $4,500 OBO for the car and all the spares
    Or $5,200 OBO with the new trailer
    The car is located in Lancaster, PA
    For more pictures or have any questions please contact me through one of the following
    Email: me_jeu@hotmail.com
    Email: jonupdegroveracing@gmail.com
    Cell: 610-509-7321
    or you can PM here I usually check it daily
    Jon Updegrove
