Results 1 to 11 of 11
    Destin FL
    Liked: 648
    Default Midyear Van Diemen Rear Upright Assembly
    Gents;
    Anyone have drawings or photos of the rear hub assembly as it is pieced together?
    Ontario Canada
    Liked: 160
    Gents;
    You might be better to list a year or years, mid-year doesn't really denote anything in the VD range.
    Cheers,
    David
    Buffalo, New York
    Liked: 269
    Quote Originally Posted by David Clubine View Post
    Cheers,
    David
    I think he means a 90 1/2 Van Diemen or maybe one made in June ...lol
    Destin FL
    Liked: 648
    Cheers,
    David
    All;
    RF-94/95/96
    Liked: 1489
    inner drive flange and outer sandwitch the bearing. Remove the bolts, the inner flange will just pop out. Outer hub is a light press fit, usually putting it in a cooler with dry ice will make it easy to press out. I usually put the upright in my gas grill and put it on low and eventually the bearing will drop put on its own.
    Destin FL
    Liked: 648
    Kirchner;
    Is there a Teflon plug with six (6) holes on the GB side of the drive flange. I am converting to MS bolts, and the cost is exorbitant. Just want to make sure on the lengths.
    Ontario Canada
    Liked: 160
    Kirchner;
    There is a teflon stopper but it sits on the center 6 SHCS that hold the drive flange and the hub together. The bolts do not go through the stopper. However if you go away from the SHCS system you will create a problem with the stopper that will have to be tackled.
    Liked: 1489
    You can replace the SHCS for hex bolts - i have some inner flanges that have an integrated tripos that use hex bolts. BUT - without hex pockets machined in the flange you may find it difficult to keep the bolts from turning - not sure there's socket clearance available.
    Destin FL
    Liked: 648
    David;
    Who can supply these teflon stoppers? I did not see them on the Primus website.
    Liked: 707
    Destin FL
    Liked: 648
    Kirchner;
    With mentorship and the recommendation of Bill Dormandy, I went with MS21250-05-66, 12-point heads. These are far superior to the typical stock SHCS.
