Results 1 to 19 of 19
    Milwaukie, OR
    Default 1986 Red Devil Autocross car
    Selling my 1986 Red Devil Formula 440 race car. This was Jeff Colegrove's car before prior to the 2011 season. I raced it all during the 2011 season and had fun with it. Now wanting to downsize my needed space for a race vehicle and so Im looking for another street car or shifter kart to autocross. Car comes with a great trailer with a tire rack, brakes, and a winch. If you do not want the trailer, we can work a price that does not include the trailer. $2000 for everything or best offer. Car comes with everything you need to get started, including 3 sets of Hoosier racing slicks, 2 of those sets with very little usage on them. Engine was freshened towards the end of the 2010 season, and I ran a light season in 2011, so low hours on the engine since its last rebuild.
    • This car won the FM class at the Finger Lakes National Tour 2010
    • Paxed #5 overall at the FLR tour out of 250+ Drivers 2010
    • RPT rank of 16 at the Toledo Pro out of 245+ Drivers,
    • in 2010 (in the hands of a better driver lol), the car did not pax lower than 3rd in any FLR regional event, including two top paxes along with one top pax from the Glen region.
    Specs:
    Wheelbase: 73"
    Track width: Under 55"
    Weight: Drivers weighing less than 175# will need ballast to meet 725# minimum
    Suspension:
    Front: Unequal length non-parallel dual wishbone suspension with QRE damper pucks, anti-ackerman steering
    Rear: Dual Novak designed and fabricated trailing links w/ bell crank and pull based dampers, QRE pucks. Aluminum watts link with adjustable pickup point (roll center)
    MOMO steering wheel with quick disconnect
    Tires: 19.5" Hoosier R25B's (1 Set take offs with new rears and older fronts, 1 set stickers with 2 national events on them).
    Wheels: Douglas 10" x 6", 7" (One set new 2010)
    Engine: Kawasaki 440 electric start w/ dual Aaen tuned pipes (fresh 7/2010)
    Mikuni VM-38 Carbs (one with enrichener)
    Primary Clutch: Polaris P-85
    Secondary: Arctic Cat Roller
    K&N air filters
    Drive: #530 chain (New 2010)
    Front sprockets: 11 & 13 tooth hardened steel (one new 2010)
    Rear sprocket: Rebel Gears aluminum 55 tooth, billet aluminum sprocket hub (New 2010)
    NTN Free spin bearings on rear axle (New 5/2010)
    Fuel Pump: Mikuni mechanical
    Fuel Tank: Tig welded aluminum 5qt tank
    Brake Calipers: Wilwood Aluminum Dynalite two piston calipers (two front, one rear)
    Brake Rotors: 7.5" Solid front (2), 10.5" Wilwood cross drilled rear (1) with custom made brake hub
    Brake Pedal: Wilwood aluminum dual master cylinder assembly with bias bar
    Brake Master Cylinders: Wilwood Aluminum MC's with integral reservoirs.
    Cooling: dual aluminum 2" core radiators (Honda) with fans and electric water pump (for cooling off in grid)
    Misc:
    Chassis setup notes / guide
    Accommodates drivers up to 6'3, currently set up for 5'9-5'11 drivers
    Impact Racing 6 pt harness
    Mechanical temp gauge
    Westach Single EGT gauge with thermocouple (New 2010)
    Digital tach
    Spares:
    4 Lightly used pistons
    Engine Gasket sets
    2 water pumps
    Spare Polaris P-85 Clutch (works fine, but could use rebuild)
    51 degree Arctic Cat helix
    Spare Mikuni VM38 carb
    Jetting to cover almost any summer conditions
    Extra needles and throttle valves
    Spare ignition coil
    2 spare fuel pumps
    Tons of bolts, nuts, washers, and AN washers
    Rivets and other specialty fasteners
    Rod Ends
    Spark plugs
    Spare recoil starter
    Drive belts
    + More that I can't think of!
    Trailer:
    Nice flatbed with winch
    Call or text... 503-933-2047
    Car is in Portland, OR
    Milwaukie, OR
    bump, price lowering. Flexible...
    Springfield, MA
    Any idea how much it would cost to get it to the east coast?
    Terra Ferma
    Quote Originally Posted by DKing38 View Post
    I'm pretty sure it was between $600-700 for me to ship it out there, plus materials to build a crate.
    Freightcenter.com is a good place to look, just make sure you're quoting with the appropriate freight code.
    Milwaukie, OR
    Bump...want it gone. throw me a reasonable offer...
    Lynchburg, VA
    PM Sent.
    Andrew Spencer
    1990 Red Devil F500
    Northern Nevada
    Default Interested
    If the car has not been sold yet, contact me. Thanks,
    Mike
    hokey@oasisol.com
    Milwaukie, OR
    Quote Originally Posted by Nevadanut View Post
    Mike
    hokey@oasisol.com
    emailed you...
    Milwaukie, OR
    bump
    USA
    I'm looking to get into this sport by building an F600 car. Would this be an appropriate chassis to begin with?
    Why is the wheelbase so short?
    Also, I am really only interested in road racing, and not much auto-x, if any.
    Atlanta, Georgia
    Quote Originally Posted by wulfgang View Post
    This would not work for your RR project. You need a more recent car (about 1990 and later). There were several changes made over the years - 1987, longer wheelbase to 80" and 1990's (?), bigger size main hoops come to mind. The earlier cars became good autox cars without any changes.
    Milwaukie, OR
    Bump...make me offers!!
    Milwaukie, OR
    bump. 2200 bucks.
    Milwaukie, OR
    Bump. Price drop to 2000 bucks.
    Enterprise AL
    Pm sent.
    Senior Member Numbskull XIV's Avatar
    Bradenton, FL
    Liked: 14
    Default 1986 Red Devil autocross car (440)
    PM Sent
    Kent, Wa.
    PM sent
    Terra Ferma
    This thing is sold and is in PA, FYI
    Bradenton, FL
    Liked: 14
    Default Red Devil
    Yep its sold and in PA, Thanks Dominic!
