Home
ApexSpeed Portal HomeApexSpeed Reader GalleryApexSpeed.blogsApexSpeed AdvertisingForums
Go Back   ApexSpeed > Formula 1000 > FB: General Discussion
Reply
Thread Tools
Old August 18th, 2012, 5:55 PM   #1
luisc1
Default gearing for blackhawk farms FB
Hay guys wanted to ask for black hawk farms what a great gearing for that track , tire i am running 8 and 10 tires right i have 14 gear in front and rear gear 46 any help guys thank's
luisc1 is offline   Reply With Quote
Old August 18th, 2012, 6:44 PM   #2
RobLav
RobLav's Avatar
A 14 in front may not be doing your chain any good.
__________________
Rob
08 Citation Dual FB/FC
RobLav is offline   Reply With Quote
Old August 18th, 2012, 7:35 PM   #3
Northwind
Northwind's Avatar
You will be fine with a 14T in the front. Depending on the tire diameter you have, you may need to drop a tooth in the rear.
What kind of chassis are you running?
Northwind is offline   Reply With Quote
Old August 19th, 2012, 4:12 PM   #4
JRMarchand
i used a 15/45 a couple of weeks ago there at bhawk, worked well i thought
JRMarchand is offline   Reply With Quote
Old August 20th, 2012, 8:22 AM   #5
openwheeler37
openwheeler37's Avatar
I'm running a 13/43 with good results.
openwheeler37 is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
©ApexSpeed 2000-2013
