At what angle can an axle be run until efficiency is lost?
Background:
We are attempting to use the existing VD rear suspension on our conversion. Where the axle normally runs the sprocket will hit the lower wishbone. We can solve this problem by moving the axle assembly closer to the engine but the axles will not be exactly straight... more like a / \.
We may also adjust chain tension by having the engine on sliders instead of the rear end. This will complicate some things (cooling, exhaust, dry-sump stuff) but we are thinking that we can engineer some movement into these items. We are only talking about less than 2" of adjustment. Still on the drawing board.
They have started cutting....
