Results 1 to 17 of 17
    Montreal, QC, Canada
    Post 1996 BRD F1200 / FV for sale
    Freshly-rebuilt Bill Vallis engine (no racing since)
    Use of carbon fiber/kevlar (chassis flat panels, floor pan, air intake, roll bar cover, mirrors)
    6 mounted Falken tires with new 15” rims (4 race weekends) as per Canadian championship rules
    QA1 adjustable front shocks
    Penske adjustable rear shock
    Heat shield
    Velo Stak
    Belts good until end 2025
    Extinguisher ok
    New battery
    Transponder
    No seat – I use a foam pad
    Electrical wiring diagram of the car
    CASC Ontario Log book
    Spares:
    2 more front noses
    Brake parts (drums, shoes, cylinders, bleeding screws…)
    Oil cooler
    2 more sets of air scoops
    Allstar oil catch can
    Front shocks
    Spark plugs & plug wires
    New oil filter
    New fuel filters
    New filler cap
    New wheel studs and lug nuts
    8 x 14” Falken tires and rims
    Engine oil, gearbox oil, brake & clutch fluid
    This race-winning car is the most cost-efficient way to drive a formula car.
    Canadian $8,000 (or US$ equivalent i.e less than US$6,000 as of today)
    Based in Montreal QC, Canada
    fxlassus at gmail dot com
    Member tsiembieda's Avatar
    Waukee, IA
    Default Brd f1200
    What size tire and wheel do you use? I'm looking for a similar set up for my vee.
    Missouri
    Default Driver size?
    What is your size and what size driver will be most comfortable? Is there adjustability in the chassis for a taller driver?
    Quote Originally Posted by tsiembieda View Post
    Tire
    Falken Azenis RT615K+ 205/50/R15
    Wheel
    SILVER 5 SPOKE ALUMINUM WHEEL - 5.5 INCH WIDE X 15 INCH DIA. (3-3/4" BACKSPACING) - 5X205MM PATTERN WITH CENTER CAP - USES 60% ACORN
    Quote Originally Posted by Huckelberry View Post
    I am 5'9.5" & 165lbs. BRD's can accomodate much taller/bigger drivers: http://vallismotorsport.com/the-brd/
    Waukee, IA
    Default Brd f1200
    Thank you, I'm going to look around to find the wheels.
    Member DannyPip's Avatar
    Wallkill NY
    Liked: 35
    I have a 1992 BRD, and I'm 225 and 5'9". I poured a partial foam seat for the lower back arch, and sit on 3/4" dense foam pad. I'm VERY comfortable and locked in nicely.
    Xavier, looks like a nice racer. Good luck with the sale. Great time of year to list it, too.
    Williamsport, PA
    Liked: 357
    it appears you do AX, but the wheels & tires you see are/were the standard F1200 & Challenge Cup package until the other year. if you want an even better wheel & tire combo (both weight & grip), we all switched to the Yokohama A052 & alloy wheels (various sources like Empi, Mobelwagen, etc).
    if you are set on that package you see, many of us have Diamond steel wheels that we have no use for now.
    Pittsburgh PA
    Interested in any trades? I have two vintage formula vees but I will be offloading soon.
    NC
    Liked: 306
    Matt, does that mean the Challenge Cup and Driverz Cup are on the same wheel tire combo now?
    Barry
    Williamsport, PA
    Liked: 357
    Barry
    Yep, we've been standardized for like 2-3 years now.
    BLS
    Quote Originally Posted by DannyPip View Post
    Thank you
    Quote Originally Posted by Keith Lawrence View Post
    Not interested in trades sorry
    Waukee, IA
    I autox at local events and which are pretty small sites. I'd like to find another options beside the normal solovee tire/wheel combo. Thank you for the suggestions I'll look into them.
  17. #15
    Default Sale pending
    Deposit received
  18. #16
    New York
    Was this a car owned by Greg rice? And has it sold?
  19. #17
    Quote Originally Posted by Dreamer21 View Post
    The car was sold and picked up today.
    As for the first question — I am afraid I don’t know.
