I'm using modern tires for the first time, previously used dunlop vintage ford tires and now I'm using 13" bias Atlantic tires. I have a question about how these tires fit the wheels:
I first mounted up a set of take-off Avons. They went on the wheels "normally" - the beads seated with about 40 PSI and they didn't leak down to any great extent. Then I got a set of the new spec Hoosiers, again take-offs but with only about three short sessions on them. They practically fell onto the wheels, beads seated with about 10 PSI, and they didn't hold air. They leaked around the bead seat area, and they would bleed down about 5 PSI per hour.
Now I have a brand new set of Goodyears. they actually measure about 3/16" to 1/4"smaller in diameter than the Hoosiers at the bead, and I can't get the bead to seat with 40 PSI - just won't pop.
What's up with this? Are there known issues with bead fitment on these kinds of tires? I read somewhere that someone had a very similar issue with Hoosiers, and fingers just pointed from wheel manufacter to tire manufacturer, both said the other guy's product was out of spec.
How much pressure is too much to seat the bead? What tricks are there? I was thinking of heat-gunning the bead to try to expand it a bit, would 200 deg F be a problem?
Thanks, Brian
