Results 1 to 2 of 2
    Liked: 4363
    Default Garage Sale (Universal Applications)
    New 16 Row Oil Coolers
    22-M22AN10-90, Setrab Series 1 Oil Cooler, 16 Row, M22 Ports
    Setrab Pro Line Series 1 coolers measure 8 1/4" long (6 7/16" not including mounting tabs) x 1 7/8" thick. The female M22x1.5 ports are 4.8" center-to-center. This 16 row size measures 4.8" tall (not including the hex on the port fittings).
    As here, https://www.pegasusautoracing.com/pr...asp?RecID=8934 , Price new, $172.
    21600ERL, Earls clone to above Setrab cooler, Price new $147.95
    Will sell Setrab for $150, Earls for $125. Both for $250.
    Spare/mock up coolers still in original packaging. Never used. Brand new! Need to go.
    Put one on your car and keep the other for a spare.
    OBP 1-liter Fuel Swirl Pot
    These are big with rally cars, but it is necessary when trying to put a fuel injected engine in an older car that used carburetors and does not have a fuel pump in the fuel cell/tank. It is all but impossible to sustain 40-60 psi of fuel pressure using an external fuel pump with the original tank pickup. So rather than replace the cell, or cut it up to modify, you can use a swirl pot as a collector. So you use a low pressure pump to pump fuel from the cell to the swirl pot, then a high pressure external pump from swirl pot through a regulator to the engine. There is a port for the regulator return. 4" diameter and about 5" tall.
    There are some very crude Chinese tanks available for less than $100, but the good ones are much more. Similiar unit here https://www.summitracing.com/parts/abt-itc305. I wanted the smallest one I could find for packaging in my FF. Mine is made in England by OBP. Without the swirl pot, I would start losing FP when my 6 gallon cell got below 5 gallons. When I installed the swirl pot, I could run it down to the last 1/2 gallon.
    $250 and I will throw in two used high pressure inline external fuel pumps. I replaced many pumps before trying the swirl pot, so I expect the pumps work just fine.
    Adding more items shortly.
    RiceRacePrep-at-gmail.com
    Liked: 4363
    Swirl pot is gone but found the brand new coolers on the shelf today ..... plus a used one.
    New price ...... All 3 coolers for $200.
