AiM Paddle Shifters for Formula Steering Wheel SW2 SW3
These paddles are new. They were removed from a new wheel that did not need them for its application.
These paddle shifters are designed exclusively to bolt to the AiM v2 or v3 Formula Car Steering Wheel Displays. Each paddle plugs into existing wiring in the AiM wheel, so there are no additional cables to run. They don't even interfere with your quick-release hub because they bolt to the backs of the "spokes", far away from the hub.To install, simply remove the two covers on the back of your wheel (2 screws each). Plug the connectors together, and mount the paddles using the four screws you just removed. That's it! The wiring for the shifters is already integrated into the AiM harness.
Set of 2 paddles, enough for one wheel. Includes new mounting screws and weather-sealing O-rings.
Does not work with v1 wheel (made until approximately 2013). The v2 and v3 wheels have 6 shift lights and 9 screws visible on the front of the wheel. The v1 wheel had no visible screws on the front of the wheel, only 5 shift lights, and the LED alarm lights were labeled "al 1" through "al 4".
$199. Free shipping to lower 48
Moses
moses@mosessmith.com
