Results 1 to 9 of 9
    Liked: 1891
    Default Wood or aluminium gear cases
    Who nowadays sells gear cases? A friend wants one for his stuff.
    Liked: 532
    Seems someone here was 3d printing now
    Liked: 961
    I find the flat wood case is a pain. No where to store it easily in the trailer or shop. The two best ideas I've seen are using the plastic stubs that pegasus sells and installing them in a rollaway box drawer. I don't have rollaway drawer space for that, so I found these
    Dewalt boxes
    https://www.dewalt.com/product/dwst0...zer?tid=576761
    https://www.dewalt.com/product/dwst1...lid?tid=576761
    Liked: 1512
    Mike Beauchamp and I can 3d print the gear spuds. I found an old toolbox with 3 drawers and a lift up lid. a gear change tool kit goes in the top, spares and cotter pins in the first drawer, tops in the second drawer, and firsts in the bottom drawer.
    I keep my 3d printed change jig and parts sorter in an old shoe box.
    The toolbox is pretty dang heavy.
    Liked: 931
    Along those lines, I have a toolbox with pieces of wooden dowel rod attached to 1/2" plywood cut to fit in the box. I have 3 layers which is plenty for me to store about 20 gearsets and some dog rings and cost very little..
    Liked: 1891
    Thanks, guys, but after talking it over this afternoon, it looks like he's going to try to find some plastic closable boxes - he doesn't have many gears (autocrossing).
    Londonderry, New Hampshire
    Liked: 111
    I'm not sure if the size of these cases is right https://www.speedwaymotors.com/Speed...xes,52680.html
    Orlando Florida 32812
    Liked: 609
    1. A friend has his gears dry and/or with a little oil left on them and zip tied together in the pair and they are all loose together in an old Army surplus ammo box securely stuffed in place in the trailer.
    2. How about each gear, following inspection, still covered in their oil from coming out of the tranny, going into a separate small baggie which gets folded over to provide some cushioning when they get stacked together.....and then cushioned via folded paper towels in between the baggies and then each set gets stuffed in a box a little bigger than the stack of gears with more paper towels on either side of the gears stacked inside the box for cushioning when in transit. The boxes are part of what has been mostly just the small boxes that my Patient's contact lenses arrive in.......sort of Mother of Invention. Eight boxes fit inside an old Attache case that go to the track. Four empty boxes (the ones in the car) four optional or back-up ratios. The other sets stay home in the drawer in the garage. All the boxes are labeled on the outside of course.
    Liked: 733
    I’m not sure this will be my final solution but I bought a Harbor Fright storage case and 3D printed some storage posts that have been slightly stretched to meet the underside of the lid so the gears stay put during transport. The posts are bonded to the bottom of the case with a structural adhesive (3M 8115). There’s room for the gear change tool and a few more gears. It’s fine for now but I might have to rethink it as gear inventory increases.
