Results 1 to 8 of 8
    Sydney, Australia
    Liked: 150
    Default Air Filters - K&N replacements
    It seems the common K&N Formula Ford air filter is no longer produced or available. There appears that our cousins in New Zealand make a very nice replacement - but its certainly on the pricey side. https://motorsportsolutions.co.nz/pa...r-formula-ford
    I have stumbled on another option - The CAL-F1000. https://performancewarehouse.com.au/...1f67da0c&_ss=r
    Anybody have any opinions or suggestions?
    Liked: 1122
    There was a British source for a reasonable replacement, but Pegasus no longer stocks them and I don't recall the vendor.
    new zealand
    Liked: 110
    The NZ one is pricey but then the NZ Dollar is not worth much either. Multiply by about 0.91 to get Aus and 0.61 to get USD.
    Not shown in the photo, it does have a nice thick CNCed bottom plate that does not crack or break or have the posts pull through. The original was almost tin plate and was horrible.
    Liked: 961
    BAT in Florida sells the ITG filters for the 32/36 DGV.
    https://img1.wsimg.com/blobby/go/4c6...et322-0002.pdf
    Ramsey NJ
    Liked: 23
    I purchased an oval foam RAMAIR filter to replace my ratty one. About $50 US on ebay. It was from the UK, with free shipping, and I got it in a reasonable amount of time. Just be aware of the height needed.
    It's not how fast you go.
    It's how well you go fast.
    Liked: 1507
    check offroad/buggy shops as well. Redline?
    CA
    Liked: 246
    Default Filter options
    Pipercross makes an oval foam filter similar in footprint to the old K&N but without the taper. Only $50-60 and last a couple years at least. Mount using tie wraps and are very simple. Just another option. Todd
    Liked: 1122
    The British outlet is DemonTweaks, selling the ITG filter:
    https://www.demon-tweeks.com/us/itg-...-9290-7000657/
    Pegasus has them, too:
    https://www.pegasusautoracing.com/pr...sp?RecID=28587
    Foam rather than paper, but should work well.
