Results 1 to 6 of 6
    Howell, New Jersey
    Default Legends Road Racing
    Can Legend cars road race in any SCCA class?
    Contributing Member Terry Hanushek's Avatar
    New Jersey
    Liked: 60
    Quote Originally Posted by Dasher View Post
    Yes ... in Legend Cars (LC) at any SCCA regional race
    GCR 9.1.C.2.b
    Legend Cars (LC) (Optional Regional Class): Cars that are manufactured by 600 Racing and that comply with current Legend Car Rules, published by 600 Racing. An LC competitor must have the current LC Rules at all events. LC should grouped with cars of similar weight, configuration, and speed potential. Note: Legend Cars are not eligible for any other Road Racing category. Modifications not permitted in the current LC rules render the car ineligible for SCCA Road Racing competition. Legend Cars may run with any DOT 205/60/13 tires.
    Howell, New Jersey
    So, is this actual road racing W2W or limited to autocross?
    Ottawa
    Liked: 1016
    Actual wheel-to-wheel. LC is typically grouped in Small Bore, but that depends on the actual class numbers in a particular Region.
    John Nesbitt
    ex-Swift DB-1
    near Athens, GA
    Liked: 903
    In order to run a legends car in SCCA, I believe you'll have to get an SCCA car LOGBOOK and have your car 'certified' for SCCA competition. .. actually HERE (below) are the specific rules for the class...
    You'll also, of course, have to be a MEMBER of SCCA .. and read up on the SCCA Rules for Road Racing in the GCR. As a newbie in SCCA, you'll have to get a NOVICE PERMIT (https://www.scca.com/downloads/3234-...-form/download) as well and follow the rules for that ... however, if you have a current w2w racing license with any organization, you might be able to get waived directly to a full competition license. You'll have to check with your Divisional Licensing Steward to follow that path. (https://www.scca.com/downloads/3236-...ience/download)
    You'll have to provide a filled out PHYSICAL exam - also available on the SCCA website (https://www.scca.com/downloads/2800-...cense/download). It's a simple form and can be filled out at most 'doc'n'box places.
    Your driving gear will also have to be REAL driving gear meeting the SCCA requirements.
    It's a SIMPLE process .. but has lots of details, i's and t's that have to be followed.
    From the GCR (General Competition Rules - current downloadable copy available at https://www.scca.com/downloads/63859...tember-updated)....
    Cars shall have two (2) red brake lights per GCR Section 9.3. Lights with fifteen (15) watt (minimum) bulbs. Engine breathers shall be equipped with oil catch tanks per GCR Section 9.3. Oil Catch Tanks, Filters, and Breathers. Minimum catch tank capacity shall be one (1) U.S. quart. All cars shall be equipped with a master switch (per GCR Section 9.3. Master Switch) easily accessible from outside the car. It should be located in the rear window just behind the “B” post on the right side. All cars are required an on-board fire system per GCR Section 9.3. Fire System. All cars shall be equipped with a fuel cell meeting the specifications of GCR Sections 9.3. Fuel Cell Specifications. All suspension Heim joints shall be captured with a flat washer(s). Arm restraints are required in all Legends Cars. A current Legends Car Rules is required to be in the possession of each entrant. Legends Cars are specifically exempt from GCR 9.3. Exhaust System, 9.1.9.A.2.d.1 (as it applies to tire protrusion from the fenders), and 9.3. Window Safety Nets.
    More questions?? Ask here
    Orlando Florida 32812
    Liked: 637
    If I remember right - because it's been easily 8 to 10 years since any have showed up - here in Cent. Fla. Region SCCA, Legends ran in SPU Class
