I was racing at Daytona last weekend and had to rent a transponder because my transponder signal suddenly became intermittent on the track receiver. After a little research I learned this is happening at many tracks across the country as new receiver equipment is installed.
Another potential issue: the transponder I rented must ‘see’ the ground so it had to be mounted on the outside of the nose. Not exactly what you want on a formula car.
The new transponders are being ‘sold’ with subscriptions of $100 per year.
Does anyone know if this will be a problem at the runoffs at VIR? If so they will need a truck load of new transponders with over 700 entries!
