![Quote](images/metro/bw/misc/quote_icon.png)
Originally Posted by
Tom Fraelich
I have the following parts/tools available for the hewland MK9. If you need photos or additional info please post here. Do not send PM.
QTY DESCRIPTION HEWLAND # PRICE
1 13-36 Ring and Pinion HC8-221M 750.00
3 4 3/8" Long Clutch Bobbin 50.00 each
4 1 5/16" Long Clutch Bobbin 25.00 each
1 Hewland Factory Ring Nut Tool 021001 100.00
5 Throw Out Bearings (Sachs) HC 245A 75.00 for the lot
2 Hewland 2nd-3rd Hubs HC8 227 100.00 each
1 Hewland 4th-5th Hub HC8-228 100.00 SOLD
5 Clutch Cross Shafts (4-16mm 1-20mm) Assorted Arms, Pushrods and Hardware 100.00 for the lot
1 Pinion Bearing German/Ring Nut Style FAG 531068A 85.00
2 Pinion Bearing German/Ring Nut Style SKF 331335 85.00 each
3 Pinion Bearing German/Ring Nut Style FAG 521676C 85.00 each
All parts (with the exception of the 20mm clutch cross shaft, which is brand new)) are in used but good condition, including the pinion bearings. If you'd like to purchase the entire lot I'll cover the shipping costs within the USA otherwise I'll add the cost of shipping to the price quoted above.
