Results 1 to 8 of 8
    San Jose, CA
    For Sale Ford 1200cc 109E Pre-Crossflow Engine- Formula Junior
    Original engine in ad is sold, but I have another one! A complete 1197cc (1.2L) pre-crossflow Ford engine. At standard bore! Comes complete as you see it- from carb to pan, fan to flywheel. Glass bowl fuel pump is not shown in all pictures, but is included. $600, less if you don't want the intake/carb/exhaust.
    Pick up in San Jose, CA or I can work with you to ship (via Fastenal most likely).
    Woodstock, NY
    Liked: 81
    Is this three or five main bearing crank?
    Chris
    San Jose, CA
    Three main bearings. Only the 1500cc pre-crossflow had five mains.
    San Jose, CA
    bump with lower price
    Ontario Canada
    Liked: 162
    Quote Originally Posted by CarlK View Post
    Actually there are some 5 main bearing 1000cc engines around. I had a Formula Junior engine in for rebuild many years ago, number on the outside was correct 105e, inside 5 mains. I believe we tracked it down to a fork lift applications from memory. We did change the crank and block to be period correct again. Not sure what ever happened to the 5 main block and crank. Rare piece for sure.
    Destin FL
    Liked: 649
    Early cross flow blocks that were available in 1967 were:
    2735 1100cc, 5 main bearing block, deck height 7.12 inch
    2733 1300cc, 5 Main beraing block, deck height 7.12 inch
    2737 1600cc, 5 main bearing block, deck height 8.21 inch
    Pre crossflow
    2730 1200cc, 5 main bearing block, Deck height 7.12 inch???
    2731 1500cc, 5 main bearing block, Deck height 7.78 inch
    Mississauga, Ontario
    Liked: 902
    I love the fact that you drive the Anglia regularly, for all these years!
    bt
    This is a 1200cc pre-crossflow English Ford engine from a 1964 Ford Anglia 123E. Comes complete as you see it, plus clutch and flywheel included. Recently pulled from my semi-daily driver after 20+ years with only valve adjustments and a new head gasket. It's a reliable engine, but it's tired. Head is 113E (1.2L). Reduced to $400.
    San Jose, CA
    bump
