Happy New Year Folks,
I'll be needing to order a new steering rack for my CF before next season, the current one's shot. (No, it can't easily be rebuilt, or re-bushed - been there, investigated that.) The Pegasus custom piece seems reasonable enough (unless someone can suggest an alternative).
Anyway, since I'm essentially starting from scratch and wil be ordering a custom configuration for my car, I wanted to change the joint between the rack and the tie rod.
My current rack has EXTERNAL threads at the ends - something like 7/8-14, and then there's a big honkin' internally threaded clevis screwed on to receive the rod end from the tie rod.
My question: if I go to an internally threaded rack (1/2-20?) and an externally threaded clevis, where do I buy the clevis (and obtain the dimensions, so I can work the dimensions of the custom steering rack)?
Alternatively, what is the approach used on modern (late '90's and newer) formula cars? Is it a "Renault style end joint" as mentioned in the Pegasus catalog? Or something different? Either way, where would someone buy one?
Erik
