Results 1 to 13 of 13
    Classifieds Super License Skelly's Avatar
    Clovis, California
    Liked: 82
    Default 2013 Spectrum FF Honda
    Up for sale is a well sorted FF car with a ton of spares
    Motor built by Quicksilver to full legal spec with .020 over pistons
    7 races on build
    Data-
    Motec with gps, rpm,mph, water temp, oil pressure and temp, break pressure, and wired for shock travel sensors.
    Gearbox-
    Built by Mark Baily in the UK
    Diff and ring gear lightened by Williams
    10:31 R&P
    Comes with 9 gearsets
    Car-
    Car has been modified from factory to maximize lightness including:
    6061 anodized aluminum floor epoxied and steel rivets. Custom anodized aluminum floor under the engine, Carbon fiber nose with honeycomb impregnated inside. Lithium ion battery(new 2021) Custom aluminum tripods, ceramic wheel bearings.
    Car weighs 1112 lbs with 1/2 gallon of fuel and a 200lb driver
    Current updates-
    New main wiring wiring harness (2021) New engine harness (2021) New sub harness for the engine (2021) New rod ends and AN hardware (2021) New throttle cable (2021)
    New oil and filter after the runoffs
    belts good thru 2025
    fire bottle recharged (2020)
    Cal Club 2019/2020 FF champion
    Car had one of the fastest trap speeds at the Indy runoffs.
    Spares list-
    Water pipe
    Radiator
    F upper a arms X2
    RF lower a-arms X2
    LF lower a-arms X1
    R upper a-arms X3
    RR lower a-arms x2
    LR lower a-arms X3
    F push rods X1
    R pushrods X3
    Steering rod X3
    R roll bar link X3
    F roll bar link X1
    Roll bar clevis X1
    Rear roll bar mount X2
    Rear pushrod turnbuckle X3
    front pushrod turnbuckle X 2
    Steering pushrod turnbuckle X3
    Rear upright clevis X2
    Rear center crossmember X1
    Rear center top block X1
    Upper a-arm clevis X2
    Rear lower a-arm clevis X2
    Master cylinder spacer kit X1
    Front Bell crank X2
    Rear Bell crank X2
    Steering rack clevis X1
    Front thru bolt washer X1
    Front thru bolt step washer X1
    Front hub X1
    Rear stub axle X1
    Rear outer hub X1
    Wheel pegs X4
    Driveshaft tripod spring X2
    Drive shaft axle X1
    Tripods X2
    Bellhousing studs X6
    Front upright X2
    RR upright X2
    LR upright X2
    rear brake rotors X3
    Front brake rotors X2
    CV boots X2
    crush box X1
    1 Aluminum and 1 steel floor under the engine
    2 noses
    1 shock cover
    2 upper side pod tops
    1 lower side pod
    1Set of silver anodized Jongbloed wheels with mounted rains
    Over $14,000 in spare parts
    $57,000 for the car and all the spares
    Please email, PM or call for any questions
    Sean Kelly
    sean1882@att.net
    559-908-3092
  2. The following 4 users liked this post:
    Clovis, California
    Liked: 82
    Default 2013 Spectrum ff Honda
    Here are the remaining that i could not post before.
    Please call or email for any questions
    Sean
    sean1882@att,net
    Clovis, California
    Liked: 82
    Default 2013 spectrum FF Honda
    Will also consider selling the car separately for $47K
    Please email or call for any questions
    Sean
    559-908-3092
    sean1882@att.net
    Member Jawz's Avatar
    Minnesota
    Default Pistons
    Beautiful car!! Good luck with the sale.
    The ad stated “motor built by Quicksilver to full legal spec with .020 over pistons” I read the 2021 GCR as only allowing Honda Fit OEM 0.25mm oversize. Did something change in the rules ? .020 generally refers to non metric system which is much larger than the .25mm (.0098) allowerd per the GCR. Asking for my own selfish needs.
    Jim Jaworski
    Swift DB6 FF
    Tiga FFA79
    Clovis, California
    Liked: 82
    Default Pistons
    Hi Jim
    Good question. That was the info given to us from quicksilver. Not sure if they meant 20mm or .020 over.
    I can check with them to clarify.
    Sean
  9. #6
    Clovis, California
    Liked: 82
    To clarify about the pistons.
    PN 13020-RB7-Z00 pistons were used. OEM .25mm over
    Thank You
    Sean
  11. #7
    Courtice, Ontario, Canada
    Liked: 131
    The pedantic toolie in me can’t resist…
    0.25mm = 0.0098”
    Stephen Adams
    RF92 Van Diemen FFord
    1980 Lola T540 FFord
  13. #8
    Clovis, California
    Liked: 82
    Default 2013 Spectrum Honda
    Sale Pending.. Thanks Mike Scanlan for the help.
    Sean
  15. #9
    Clovis, California
    Liked: 82
    Car is sold.
    Thank you apexspeed !!!!
    Sean
  17. #10
    Oakland, California
    Liked: 78
    Default Good deal!
    Someone got a great car! Well done, Skelly!
    _______________________
    CornerSpeed
    1979 Van Diemen Club Ford
  18. #11
    Clovis, California
    Liked: 82
    Car is being picked up on wednesday and heading to IN. The car has enough spares to last the new owner many years,
    Sean
  20. #12
    Fenwick, Ontario, Canada
    Default Still Available?
    Is this car still available?
  21. #13
    San Francisco
    Liked: 77
    Default Gone
    Sold long ago
    Hybels
