Results 1 to 15 of 15
    Liked: 555
    Default Pushrod Bellcranks
    *** SOLD ***
    I bought these for a project but didn’t use them.
    Was told they are from a Vector with an LD200.
    Seens like a good quality piece.
    $70 plus shipping.
    Liked: 555
    The “longer throw” arm has a 5/16” hole. The gap rod end/shock eye clearance is .75”
    The shorter throw arm has two .375” holes to choose from, and the gap is .5”
    San Jose, Ca
    Russ, how thick are the rockers? I assume the bells that go through the rockers just screw into the aluminum bracket? What are the bolt hole dimensions from the rocker center?
    Liked: 3335
    Those look like they are a pretty low motion-ratio (MR) setup. You should do an analysis of the total setup you plan to use these with to determine if the MR suits your situation before buying.
    San Jose, Ca
    Agree completely completely Dave. I’m just trying to determine if they would fit dimensionally in what I have. Or copy the bearing design but make new with the MR I want.
    Liked: 4364
    The Vector bellcranks are really nicely made. They are not just folded up sheet metal. Redrilling holes or adding tabs to suit would be far easier than making anything from scratch. I think this assembly is a bargain at 3 times the price.
    Liked: 555
    Got your PM. Thanks. I will get the other measurements to you later today.
    Thanks, Greg. Yes, they seem like a high quality set up. They're just gathering dust in my garage. Hoping someone can use them.
    Liked: 555
    Please see next post with picture and measurements.
    Liked: 555
    Oops. Better picture:
    A --> B = 4"
    A --> C = 2.25"
    A --> D = 2.75"
    A --> E = 2.5"
    San Jose, Ca
    Thanks Russ. What I'm really looking for is the design details of how the rockers pivot on the post. I don't have a narrow enough chassis to add the entire mount to. My chassis is much wider so this would have to be fairly high up to afford clearance for pushrods.
    Liked: 555
    If you'd like I could ship it to you for evaluation.
    Or, send me a PM with your email address and we can discuss options.
    Maybe you could cut it in half and refabricate it with the width (and different angles) you need for your design.
    Liked: 555
    Bump.
    Will sell for $20 plus shipping.
    NC
    Liked: 306
    Bump.
    Russ, I'll take them. Have no current use for them but someday...
    Ill send PM
    Liked: 555
    Barry, I got a PM a few minutes before yours.
    I’ll let you know if that sale falls through.
    Thank you.
    Ill send PM
    BLS
  16. #15
    Liked: 555
    Sold.
    Thank you.
