ALL CARS SOLD JUST PARTS REMAINING
All of my F4 cars have been gone for a few months. I have edited this word doc with updated parts inventory and it has a link with photos of all the items.
I went through the price sheets from Ligier, to buy all of this new you’ll be about $22,000USD. Initial thought is $10,500USD + Shipping for the allotment, let me know thoughts, questions etc. Need it all gone to have that chapter officially closed.
: All spares are new unless stated otherwise
- 1 Fire Bottle
- 1 Front T-Tray Floor
- 1 Rear Floor
- 1 front T-Tray floor – USED
- 1 Rear floor – USED
- 1 LH Side pod – USED
- 2 LH Front Side pod - USED
- 1 Radiator Assembly (need mounting tabs re welded)
- 1 temp sensor
- 1 used temp sensor
- 1 rain light - need repair
- 4 coils
- 4 Injectors – used, perfectly good
- 2 cars worth of steering rack sensors and mounts
- 2 fire battle wiring harness kit USED
- 1 TPS sensor
- 1 fire bottle battery power box USED
- 1 gear indication sensor USED
- 1 starter button & ignition power harness kit USED
- 2 AIM beacon receivers USED
- 2 nose blocks
- 7 suspension mounting pick up points USED
- 1 rear toe hook USED
- 2 oil pump belts
- 7 different oil lines
- 1 exhaust USED
- 1 over flow can USED
- 1 overflow can filter
- 2 wheel bearings
- 1 starter REBUILT
- 1 front sway bar USED
- 1 slave cylinder
- 1 rebuilt clutch face with new fingers
- 2 rear upper wing flaps – both new 1 has small blemish on end which pictures shows
- 1 roll hoop cover
- 1 rear axle assembly V1 style USED
- 1 oil cooler air duct USED
- 1 set of Hankook wets, still have nubs.
- 5 Rear Wheels
- Front & Rear Toe Bar assembly
Pics: https://myalbum.com/album/5x5YbVTsQDHChF/
