Race Car is Sold! 04/07/21
For sale 1981 Van Diemen RF81 CF Race Car. Raced with Rocky Mountain Vintage Racing in Colorado since 2016 with current RMVR log book. The car was tech inspected and passed inspection on 05/21/20. The car was raced in three race weekends in 2016, two race weekends in 2017 and one race weekend in 2020. Race car sat unused for three years due to Owner illness from September 2017 until August of 2020. This car consistently ran in the top five of the FF race group. Won one race in it's first race weekend with the current Owner at High Plains Raceway, CO RMVR RAKC 2016, won the 2016 RMVR Enduro at High Plains Raceway, CO and has ran 2:00 lap times at High Plains Raceway, CO and 1:34 lap times at Hastings Motorsports Park in Hastings, NE. A very well setup car, easy to drive and with the right driver and the right skills could be a front runner in the FF group. This is a very desirable car for the CF racing group. This car would be eligible to race in most Vintage Racing Organizations in their FF group. The car has been recently corner weighted and weighted to meet SCCA minimum weight of 1100 lbs with driver and no fuel, set toe front and rear, camber front and rear and ride height set to specs. The engine was rebuilt July of 2017 and has approximately 6 hours and 40 minutes on it. New +5 CP pistons, Total Precision Engines custom ring set, new main, rod and camshaft bearings, timing chain, tensioner, cam sprocket, full gasket set, fuel pump and valve seals. Block and head pressure tested and Mag tested, re-surfaced cylinder head, planed top of block and power honed cylinder walls by Total Precision Engines. Fiberglass body is in average condition with some cracks near rollbar cutout and rear shocks and some rock chips on front nose. The Van Diemen chassis number is : 507. Owner history can be found on the Van Diemen Owner Registry at http://www.vandiemen.registry.freeservers.com.
Car comes with the following equipment:
New Taylor Racing light weight Lobro CV joints with aero boots installed 7/2018
Custom made FuelSafe fuel cell installed in existing steel fuel tank installed 04/2016 with six race weekends on cell
Brand new Hitech custom stainless steel exhaust header installed 02/2020
Cast iron steel head originally prepped by Arnie Loyning, with recent Curtis Farley head prep including valve job, springs and valves
New exhaust gas temperature sensors (2) with gauge installed 07/2020
2 sets of Revolution wheels, one with new set of American Racer slicks with (1) race weekend on slicks, one set of Revolutions with Hoosier A2500 racing slicks unmounted with (2) race weekends and two afternoon practice sessions at HPR on slicks
New Ecliptech electronic shift light
New Stack Clubman tachometer 0 to 8000 rpm face
New Farley prepped Weber downdraft racing carburetor with re-usable Pipercross foam air cleaner and custom throttle cable with springs
New front and rear brake discs with new Hawk Black racing pads front and rear
New Girling front master cylinder and rebuilt front and back brake calipers installed 03/2021
Existing Van Diemen fiberglass seat covered with padding then black Nomex fabric
New Momo D shaped open steering wheel with quick disconnect hub
Brand new OMP 6 point racing harness with 2" belts never used good through year 2025 installed 02/2021
Ron Davis aluminum racing radiator
Ballistic 16 cell EV02 battery with custom charger
Intimidator AGM deep cell jumper battery with cable
New lay shaft with roller bearing, front oil seal and shaft coupler
(23) sets of gears for Hewland MK9 gear box including gears for HPR, Pueblo and Hastings
New Tilton 7.25" clutch disc installed 08/2016
New 123 electronic programmable distributor with new set of custom plug wires
Penske nitrogen filled 8100 shock absorbers with Nitrogen Bottle, filler valve and gas gauges
Freshly rebuilt steering rack. Rack rebuilt by Keith Averill January 2017
Custom made aluminum front and rear setup bars with strings
Wood, homemade scale platform with ramps and (4) glass bathroom scales for corner weighting car
Additional spare parts that came with car when purchased.
Purchaser is responsible for all related delivery costs from Greeley, Colorado.
Extras available for purchase at additional cost:
Set of four Panasport Megalite custom wheels in excellent shape with 4 year old, never used set of Hoosier A2500 slicks. These wheels weigh 6.6 lbs each and are very difficult to find. Wheels and slicks for $2,000. Wheels only $1700. Wheels and Tire are SOLD
(1) aluminum cylinder head recently refurbished by Curtis Farley with 4 hours of racing time on head $1,200 SOLD!
(1) cast iron head that came with car when purchased, includes valve springs and valves New Price $500
New Aim Solo 2 DL data logger and GPS lap timer with Race Studio software purchased in June of 2020 with RPM filter to clean up signal interference from distributor. Used only one race weekend. $650. AIM SOLO 2 is Sold
New Aim Smartycam HD Revision 2.1 with 84 degree lens purchased June of 2020 with camera rollbar mount and connection cables for data logger. Used only one race weekend. $1000 AIM Smartycam is SOLD
Brand new engine stand for FF1600 engine, never used $125 SOLD!
1996 16' Sport Trailer fully enclosed trailer includes 4 brand new tires, tandem axles with brakes on both axles.
Fits FF race car perfectly. Has E track and snap in tie down D rings included $2,200. Race car must be sold before the 1996 16' Sport Trailer can be sold separately. 16' Sport Trailer Sold with Race Car.
Yamaha 750 watt whisper quiet generator for use with Sport Trailer $500 Generator is SOLD
2005 Keystone Raptor 34' Model #: 3018TT Toy Hauler with 19' garage space and new aluminum ramps to load car in trailer. This trailer works perfectly as a FF car hauler and camping trailer for race weekends at the track. Trailer has 6 new trailer tires and Hensley trailer hitch that is valued at $3000 new. Includes Onan 5000 Gold generator with only 460 +/- hours on it. Generator fuel supply lines, plugs, air filter, oil filter and carburetor all replaced July of 2020. Includes ATV fuel station with completely rebuilt pump in June of 2020. Comes with tire pressure and air temp monitoring system for both trailer and tow vehicle. $16,500
More pictures can be supplied if interested by contacting me at brdwlkbldr at aol dot com. Thank you.
You can contact me directly at Nine Seven Zero - Five Three Nine - Seven Five Nine Six. Please leave me a PM if interested.
