Results 1 to 9 of 9
    Moyock, North Carolina
    Default F5 ballast questions
    Hey guys,
    how are you attaching ballast to your car trying to figure out a way to attach that is easily removable since we have two different drivers driving the car
    Senior Member lance3556's Avatar
    Aloha, Oregon
    Liked: 28
    I have thick seat bottom that I plan to cut a couple pockets in to slip in some lead dive weights. I have in the past slipped some ankle weights jammed between the front of my lower seat cushion and the fire bottle.
    Default Ballast
    Where you put your ballast and what do you want your weight distribution to be? Are very interrelated This is an important tuning tool!
    N.E. OH
    I remember a post someone had, I think on f550.us, where they had put a brace across the bottom of cockpit with a post sticking up in the middle. They would put the weight down on the post and it had a cotter pin type of connector to hold it in place. They had pictures of the install and it was pretty slick. I just looked on f500.us and couldn’t find the post. Perhaps this will jog someone’s memory and they can find it for you.
    Liked: 227
    It's somewhat depend on the ballast material, shape and weight. I used a block of lead. Drilled a hole through it and bolted it to the belly pan.
    Ft. Myers, Florida
    Liked: 225
    Default weight
    On one of my cars I used lead weights that were 1"x1"x6" or so and built a locker for them on the floor. I think I had 5 or 6 or them and that they weighed about 2lbs each. I "tuned" the weight by replacing a lead weight with a 1x1 square aluminum dummy to take up the space. This allowed me to subtract only as much as I needed for varying weights (or scales, let's be honest). Lead weights were made by melting and pouring into a proper sized mold.
    Locker was 1x1 aluminum angle bolted to the floor with a lid that screwed to nutserts.
    Sure wish I needed to ADD weight these days!
    John
    Huntsville, AL
    Liked: 57
    I have always carried my ballast weight inside my driving suit. [emoji15]
    George Bugg
    NovaKar
    F600
    Liked: 227
    Quote Originally Posted by GBugg View Post
    Amen! Been a long time since I had to add weight to a car.
    Las Vegas
    Liked: 82
    I'm 145lbs...……………….I put a farm tractor battery in the car. I don't need a jumper to start the car every time.
