Results 1 to 8 of 8
    Michigan
    Default 2013 Van Diemen DP08 FC Zetec/LD200
    2013 Van Diemen DP08 F2000/Continental<br>
    Ford Zetec by Quicksilver<br>
    Four Speed Hewland LD 200<br>
    Aim Micron XG log W/ Beacon<br>
    Hard wired transponder<br>
    <br>
    New and or one season use:<br>
    Sabelt Safety Belts valid until 2024<br>
    Bell Housing<br>
    LD 200 Hewland Gear box<br>
    Rebuilt/Dyno'd Quantum Dampers<br>
    Rear Shift Rod<br>
    Ignition Ciol<br>
    Throttle Position Sensor (TPS)<br>
    Engine oil cooler<br>
    High Flow Engine oil pump by TDC<br>
    Clutch complete including slave cylinder, release bearing, Tilton 7.25 single disc<br>
    <br>
    Spares new:<br>
    One front right upper control arm<br>
    One front right lower control arm<br>
    One Throttle Position Sensor (TPS)<br>
    One water temperature sensor<br>
    One engine oil temperature sensor<br>
    One set of fuel injectors<br>
    Two sets of rear wings uprights<br>
    Two sets of front wings side plates<br>
    <br>
    Spares Used:<br>
    Two sets of wheels-One mounted slicks-One mounted rains<br>
    Extra two front wheels-mounted slicks<br>
    One Bell Housing<br>
    One front nose with wing support<br>
    One factory diffuser<br>
    One set of side pods<br>
    One set of rear wings-upright<br>
    One set of front wings-side plates<br>
    Two radiators<br>
    One set of brake rotors<br>
    One liquid to liquid engine oil cooler<br>
    Nose/wing assembly carrier<br>
    One set of wheel lug nuts<br>
    <br>
    2019 Major and Hoosier Super tour-one win and one second and two third places. Asking $29,500 for all. <br>
    Serious inquiries only, please. Interested parties contact Carlos Franca at <a href="mailto:gfracing1@yahoo.com">gfracing1@yahoo. com</a> or phone 248-499-2343.
  2. The following 4 users liked this post:
    Michigan
    Default 2013 Vandiemen DP08 FC Zetec/LD200
    Thank you ApexSpeed! the car has been sold
    St. Charles, Illinois
    Liked: 180
    Where did the car go?
    Michigan
    The car went to an excellent home in Kansas
    Kansas City
    Liked: 110
    That's good news for me, second new car in my area for this year. Can you tell me or PM me the new owner?
  9. #6
    Michigan
    Hi Bill, I will check with them.
    Carlos
    Deep River, Ontario, Canada
    Liked: 120
    Default The right package
    Quote Originally Posted by GFRacing1 View Post
    $30k ?
    I rest my case.
    Shame on us all for abandoning F2000 one way or another.
    KR
    Muncie, Indiana
    Liked: 996
    If FC produces anything even close to numbers indicated in the Indy Runoffs survey then 2021 is going to be one of the strongest seasons that the class has ever experienced. This is going to be a year no one will want to miss!! And, with Runoffs then going to VIR for two years I think we are in for one helluva run!
  12. The following 4 users liked this post:
