Hi folks,
I had a few PMs/comments where people asked about my rig so I thought I'd post a few photos and sketches in case anybody wanted to use this as inspiration for their own.
I used 80/20 aluminum extrusion instead of steel for a few reasons:
1) Much lighter; I regularly slide this out of the way to allow me to work at my desk, so this helps
2) Infinitely adjustable; every segment can be slid and adjusted against all the others
3) Reuseable; if I ever don't need this, these pieces can easily be used for something else, or resold
I also used some 3/4" Baltic Birch plywood as part of my design:
1) Much cheaper than using 80/20 for everything
2) Easier to create stability across multiple directions without a ton of triangulating braces
My overall design philosophy was that I wanted this thing to be stiff and sturdy at the lowest possible cost and weight. There are a million 80/20 designs out there - there are some best practices and well reviewed cockpits that I emulated and also a great many designs that are either weaker or heavier (and more expensive) than needed. I designed this based on my gut feel, but now that I have built it, I am extremely pleased - it absolutely exhibits no noticeable flex or vibration in any direction.
-Mark
