I recently broke a throttle cable at the bulkhead fitting on the end of the 7mm housing. This piece had an m6 x 1.0 stud on it that held the housing against the fan cooling structure (vintage lynx b).
I have been trying to source out materials for building new cables. I am not able to find these cable housing end pieces, bulkhead threaded rods, for 7mm or 5mm cable housings. I am not able to find long (40mm) cable end 5/32 ferrules to clamp down in the carb.
I am trying to repair this cable to have as a spare and build several new ones as well.
I am trying to use the existing aircraft s.s. 1/16-3/32 7x7 cable.
Does anybody have sources for these parts? This cable may be decades old and I may need to rework the pedal if parts can't be sourced. The cable goes from a 7mm housing on the carb end to 5mm housing thru the frame to the pedal.
Is there a better way to build this cable today?
