Results 1 to 10 of 10
    Columbus, OH
    Liked: 482
    Default What gears are these???
    Any ideas. Came with my car but I don’t think they go with my Staffs box. Dunno... the set on the far right has a smaller diameter dog ring circle.
    Liked: 1415
    First gear pairs for a Mk 8-9 Hewland
    Arlington, Texas
    Default Gears
    The two gears to the left are LD200 first gears, the gear on the right is MK8-9 gear. Steve put on your Bifocals.
    Member scotty82's Avatar
    Denton, Texas
    Liked: 63
    But ....MK9 will have a 1.040 Major ID of the spline , While the MK5 will be 1.162 Major ID. Mike is correct , the tops of the lugs on an LD are in the shape of a roof.
    Scott Young
    Scott Young Enterprises
    scotty@sy-gearboxes.com
    Columbus, OH
    Liked: 482
    If I’m measuring the GEARS what is the Major ID? I want to understand clearly.
    Liked: 860
    The bigger ID
    Columbus, OH
    Liked: 482
    Quote Originally Posted by scotty82 View Post
    I measure 1.035... so I have a Staffs box set up for Mk9 gears, correct?
    Liked: 860
    The Staffs 4 speed uses Mk 8/9 gears, the 5 speed uses Mk5 gears
    Columbus, OH
    Liked: 482
    That was my understanding but I didn’t want to assume that. Note:
    https://www.apexspeed.com/forums/sho...-Mk-9-amp-Mk-5
    It seems there were some conversions. Steve D has a Mk5 in a car like mine I think.
    Liked: 929
    The major diameter of the spline is the same as measuring over the top of the splines n the shaft, right?
    Actually I have a Staffs most probably like you probably do Eric. Steve used them pretty much universally for a long time.
    The Staffs came in 4 or 5 speed, just like the MK series. Just the 4 speed has some sort of a spacer where either first or first would go on the 5 speed MK and I think the same on the 4 speed staffs.
