Originally Posted by
I'm making the assumption that the black piece is aluminum wheel spacer.
It's likely that the spacer has corroded to the wheel studs. If you can get "Kano Labs Aerokroil", I've heard that stuff will free anything. If not, spray some brake fluid down the wheel stud threads, let it soak for a bit, then tap down (deep socket over wheel stud), then tap out.
Be careful tapping with a rubber mallet. Even a rubber mallet can crack the rotors if you tap it anywhere near the OD.
