I agree with the "no minimum weight rule".
It's what the Prod cars run, and if you want to see some scary flywheels, look at some of the stuff those guys run.
First, machine off ALL of the flywheel everywhere, down to 0.00ohmygodthin, THEN, cut large "windows" just completely removing 75-85% of what's left for material anyway, oh yeah, leave somewhat enough area to catch some of the friction material from the clutch disc, and you might want to leave it just a little extra thicker under the ring gear, don't want that coming off, eh.
Atleast that's what I've seen of the guys that don't go spend the money for trick aluminum flywheels. Either way they weigh absolutely nothing, and then get turned 9,000 rpm+
If the CB board is hesitant about "going all the way down to 15.5#", I think it's unrealistic that they'll give us a zero min. It would be nice though, and it would probably help Enterprises too, make their crank look good by never failing, after taking away all the bad harmonics and stuff that was previously caused by the too heavy flywheels.
I do agree it's another stop-gap measure, those that go real close to min now, in a few years will have the same problems again. Let's see, 2# lower every three years, that ought to about do it.;)So we can revisit this rule how many times in our lifetime to get to a zero min?
Though the flywheel replacement price is currently helped(lower) by the proposed flywheel, so the 15.5# rule should help 1-engine life, 2-costs. Still a step in the right direction.
I sent my positive feedback to SCCA, did you?
Marc
