Page 1 of 2 12 LastLast
Results 1 to 40 of 50
    Burlington, WI
    Liked: 391
    Default FV Track width change approval
    The CRB has made a terrible decision in it's latest clarification of the FV track width rules. If you do not want to increase the front track width of your FV, I highly suggest voicing your opinion to the CRB.
    The maximum track width that is listed in the GCR was there for those choosing to use a 4.5" wheel. It was put in place at a time when the 4" wheels were unavailable. It allowed the use of the wider wheel without exceeding the previous maximum track width. There was no way to legally achieve the maximum track width without using the wider wheel.
    The CRB has now regrettably allowed the disc brake kits to be made wider to reach the maximum track width with the standard wheel. They are now also allowing spacers for those who wish to stick with drums.
    I believe this is a horrible decision and serves no purpose. Again, I highly suggest those opposed to this clarification submit a letter immediately expressing your opinion.
    Liked: 4363
    No purpose?
    For several years, we have heard people complain that the track rule prevented the use of "off the shelf" disc brake parts and required using manufactured custom disc brake components. Does this new change allow for the use of much cheaper disc brake components? If so, it would appear to be a major cost savings for competitors. If this is not the case, then someone should propose another option that would allow the use of more affordable brake components. In typical SCCA style, the whole concept and process, is insane, but fixing it now, is better than letting it continue at obscene cost. Of course, leaving it as-is (as in for 55 years) would have been preferable.
    BTW, I buy custom wheel spacers for $20 each. If someone did a run of FV spacers, then $50/car would seem a reasonable projected cost for drum users to increase their track.
    Ohio
    Liked: 247
    With all due respect this was caused by the disc brake rule being written but not fully thought out. Had the track been addressed in original disc brake rule then we wouldn't even be talking about this.
    This is a situation where an opportunity presented itself to have the track width optamised and people took advantage. You cant go back now and undo that when people have taken the time to develop and produce parts that are perfectly legal by the GCR. The cat is out of the bag per say and we're past this.
    The other concern is that if this were to be changed it would effectively make a monopoly for one of the disc brake kits as the others wouldn't be legal. To me that's a conflict of interest.
    The right thing to do is to allow the drums spacers so all is equal. As Greg said this will allow people to use the heavier Chinese kits if they so please as that extra inch helps tremendously.
    One of the disc manufacturers didn't catch the opportunity and itll probably be harder to update their kit, that shouldn't come at the expense of all others though.
  7. #4
    Senior Member Amon's Avatar
    Medina, Ohio
    Liked: 174
    Burlington, WI
    Liked: 391
    No purpose?
    The track width was not changed enough to allow any after market kits to work.
  9. #6
    Burlington, WI
    Liked: 391
    Quote Originally Posted by B Farnham View Post
    Funny how no one had an issue with making wheel fairings illegal after the fact.
    The intent of the allowance of disc brakes was to avoid any performance advantage. This change completely eliminates that concept and was completely disregarded.
  11. #7
    Williamsport, PA
    Liked: 357
    I agree with trying to not allow performance advantages.
    However, could you explain how this is an advantage now that SCCA allows more width? I have been working under the assumption that narrow is better aero, so anything wider is a disadvantage. When all the 4" vs. 4.5" wheel talk came up with the disc brake kits, I was a bit confused, since literally every VW wheel I have is the narrow one.
    edit: to clarify- I do know that FF has wide track kits, but F1 went narrower in the late 90s. I guess my question is, what is the preferred thinking for FV in 2019?
  12. #8
    Ohio
    Liked: 247
    The track width was not changed enough to allow any off the market kits to work.
    They may not work off the shelf but can be modified to.
    The illegal fairings was before my time but I read about it. Unfortunate how it turned out given the investment you made but two wrongs dont make a right.
    The intent was to allow the discs without an advantage and with allowing the spacers for the drums that still holds true.
  13. #9
    Liked: 58
    ProblemChild mentioned spacers can be purchased for ~$50 for those of us with drums who choose to maximize our track. Is $50 really catastrophic when it also allows the class to move forward a tick? I don't think it is. I have the Veeline book that documents hundreds of changes to the class since its inception.
    1993 Citation FV
    NEFV - 2022 Champion
    NERRC - 2022 Champion
  15. #10
    Couple thoughts from the peanut gallery:
    "Wheel fairings" weren't wrong, IMO, if they were legal before the GCR was changed. They were just something that was undesired by the class/powers that be, so the rule was changed. Not necessarily wrong either, but it sure does suck. I don't like changing rules in the middle of the game.
    The disc brake option would have never been approved if it was perceived to be an advantage over a properly tuned drum set up. The track had to remain the same or the perception would have been they were an advantage (I believe they are, even at the same track width). The Varacins went through the time, trouble and expense to engineer a kit that would work within the ruleset. Now, the goal posts are moved again, so that much more affordable options can be explored and there can be more crossover between series.
    I think that's better for the class as a whole, but certainly removes the incentive (again) for folks to move the class forward in performance/technology----but perhaps that's the entire point.
  16. #11
    Ohio
    Liked: 247
    I agree, the wrong was in regards to how the rule was changed and they were made illegal when per the GCR they should have been fine.
    The issue here is the rule that was written was done so poorly. When I heard about the discs one of my first thoughts was to increase the track as building them wider without a spacer satisfied the rule (something you couldn't do with drums).
    So the question is who or what committee wrote the rule and how did they miss on this? You cant blame those that exploited the rule but those who wrote the rule that could be exploited.
  18. #12
    Liked: 292
    Exactly what is the proposed change? I do not see it in Fastrack.
  20. #13
Name:	Screen Shot 2019-04-16 at 10.31.11 AM.png
ID:	84898   Click image for larger version.
Name:	Screen Shot 2019-04-16 at 10.31.30 AM.png
  21. #14
    Torrington CT
    Liked: 482
    A quick search finds that back in 1967 the front track max was 51.4 I assume this was with 4" wheels
    The current GCR (April) says 52.5" (no spacers allowed)
    I will have to go back and look through my GCRs but this was probably when aforementioned wheels (4.5) were brought in.
    So if you ran 4" wheels you would be under it, if you ran 4.5 you would be at it.
    If the Comp Board is now saying the max is 52.5 - with or without spacers - that could make things complicated......
    Could I run 4.5 on the LH side at Lime Rock.....
    So what is the exact wording of what they are proposing?
    ChrisZ
    I see if got posted above me...
  22. #15
    When a rule change is disguised as an E&O correction. . . .
    Love me some SCCA.
  24. #16
    Williamsport, PA
    Liked: 357
    I think this is sounding like fallout from a short-sighted & vague rule change.
    I realize it had to start somewhere, but it wasn't hard to see issues that were going to come up almost immediately.
    That being said, I again say that maybe allowing a bit of extra width is not a bad thing to start with.
  25. #17
    Liked: 292
    So the use of spacers is the only change?
    Then a disc system optimised to 52.5 using 4.0 wheels and no spacers would preclude the optional use of 4.5 wheels.
    Where as a disc system optimised for 4.5 wheels could use 4.0 wheels and a space to get the max track.
    Is this correct logic?
    Liked: 292
    Where and when?
    It would depend on what makes it into the May GCR.
    The E&O rule correction does not allow the use of spacers, it removed the words saying they weren't allowed. This might imply that their intent was to allow them, however If It Doesn't Say You Can, You Can't and they very well may have been attempting to remove rules prohibiting modifications where such wording isn't required.
    The response to Varacin's letter suggests that they want to permit the use of spacers, but nothing in the current rules, or the proposed E&O correction states that is the case.
  28. #20
    Where and when?
    When what was illegal yesterday, is legal today without going through customary procedures to change rules.
    Errors and Omissions should be reserved for just what the clause states; ERRORS and OMISSIONS. Typos and rules that were in a previous GCR edition that were mistakenly omitted from the current edition.
    After somebody goes through the trouble of engineering and manufacturing a kit to meet current track width rules, and then the track width rule is changed, that's not an error and omission, that's a rule change. Perhaps the rules-writers erred in their thinking of what should be proposed, but changing what was proposed and approved to something they didn't foresee is a rule change.
  29. #21
    Ohio
    Liked: 247
    The thing is that the track rule wasnt changed, the discs rules were written and no one accounted for the increased track for the 4.5" wheels that happened some years ago
    Changing the track rule so that only 4.5" wheels could be used to achieve max track would be a rule change. What SCCA is doing is they realize that the rule for the discs wasn't written well and in an effort to make the drums on a level playing field have removed the language for "no spacers".
    More or less the rule was misinterpreted by one of the builders and their kit wasnt optimized.
  30. #22
    Burlington, WI
    Liked: 391
    Brian,
    Nothing was misinterpreted. Before the allowance of spacers and disc brakes, there was no legal way to get to the maximum track width without the wider wheels. The disc brakes were approved with the understanding there would be no performance advantage and no dimensional differences from the drums. That was the basis of the approval. By allowing them to run at the maximum width and changing the rules so drums can match it, that is in effect, a rules change.
    If there was a legal way to run 4" wheels at the maximum track width prior to the discs, or if the disc approval wasn't based on dimensionally identical components, this wouldn't be an issue.
    Anyone building a disc kit was well aware that discs were allowed with the understanding they were to be dimensionally identical to the drums. If someone chose to push the limits and neglect this, then that was a risk that should be on them and in no way should the rules be altered to accommodate.
    The point of this post is to make those who are not following aware that there is a proposal on the table to now have a legal way to widen the front track of thier vee. If you do not support this change, you have a small window to express this to the crb.
    Thank you,
    Michael
  31. #23
    Liked: 292
    Up to this time there has been no interest in the possible use of spacers to increase the track of 4.0 wheel users. Why is that?
    What was the reason for the no spacers rule? Why the reduce track for the 4.0's when compared to the 4.5's? Was there a perceived performance reason?
    Ohio
    Liked: 247
    Brian,
    Thank you,
    Michael
    I feel the misinterpretation is that the disc brake rule outlined that the track be the same as the drums. This wasnt the case as the GCR just specified what the max track could be, not how one could get there.
    "FV 1. #22456 (Formula/Sports Racing Committee) Disc Brakes in FV - Member Survey At the recommendation of the FV ad hoc committee, the CRB recommends the option of disc brakes in FV. Add the following:
    9.1.1.4.D. Front and/or rear brake drums and backing plate assemblies may be replaced with a disc brake conversion assembly as an option. The front spindle/steering knuckle, rear axle, axle tube, bearing housing and bearing retainer/seal assembly must remain per GCR part 9.1.1. A spacer plate or a portion of the rear caliper support may be fitted beneath the bearing retainer to replace the backing plate dimension. Any ferrous alloy, unvented rotor may be used, but must have a maximum diameter of 11.75 in. and a minimum thickness of 0.20 in. The otherwise smooth rotor may have a maximum of three pad cleaning grooves per side. Any ferrous or aluminum alloy caliper and caliper support may be used. The caliper must have no more than four pistons and weigh a minimum of 1.65 lbs. Brake pads are free. Any hub assembly may be used as long as it can be fitted with part 9.1.1. wheels. "
    I dont see anywhere in the disc brake rule that states that dimensionally identical components must be used.
    No current rule is being altered to allow the other brake kits, they are legal by the GCR. In shooting this proposal down it would do nothing more than put the drums at a disadvantage.
    The cat is out of the bag, those who wrote the rule missed what door they opened. I dont see why many would be against this unless you purchased a narrow track brake kit. Those with drums could easily add spacers and it would allow for more creativity with using off the shelf kits.
  34. #25
    Liked: 292
    That is because this was the stated premise that was presented to competitors to get their approval of the brake system change. It does not have to be part of the written rule. Those who stay with drum brakes expect nothing to change on their part. That is what they think was approved.
    Al Varacins did not miss an opportunity. He was precluded from doing anything that would change existing drum brake setups by the proposal presented to FV competitor.
    I repeat my question, why were wheel spacers restricted/banned when 4.5" wheel were approved for use? You just do not add such a restriction without a reason. Relative to track width, it put 4" wheel users at a disadvantage, yet there has never been a push to correct this.
    I do not think we have all the facts.
    Torrington CT
    Liked: 482
    Brian,
    I have yet to find the details (I think it happened in 2006)
    There was a shortage of NEW 4" wheels (I do not think there is a real shortage of used wheels but that is another question)
    So 4.5 wheels were approved.
    They have 1/2" more offset so that must be why the track was widened to 52.5"
    Cons
    They weigh more
    They add more tire area so more drag.
    This must have been assumed to cancel out the increased track width.
    The rule should have been written:
    4 " wheel = 51.4" track max
    4.5" wheel = 52.5" track max
    and we would not be having this discussion.
    The no spacers was to keep people from moving 4" wheels to the 52.5" measurement. (I understand people are getting tricky with "adjusting" other suspension parts to get the extra track - again - if the rule had been written as above, that would not be legal either.)
    So before the CRB gives out an "clarification" someone should explain that understanding the rule is important before clarifying it.
    ChrisZ
    I see another "manfold" "wheel cover" "carb jet" situation coming up where we retroactively fix something.
  36. #27
    Liked: 292
    Yes, agree with your assessment of the issue.
    That last thing the class needs is a performance preferred 4" wide wheel that can only be found in junk yards/used and must be refurbished. Does not sound very user friendly.
    Write the CRB to maintain the .5" (or is it 1"?) difference in track width between 4" and 4.5" wide wheels.
    IF the offset of two wheels are the same, the track width doesn't change. A 1" wide wheel and a 12" wide wheel each of zero offset, for example, produce the same track width.
    Is the mounting surface of the 4" and 4.5" wheel offset the same amount from the center line of the wheel?
    If the backspacing is the same then the 4.5" wide wheels will result in a .5" wider track width when used as a pair.
  38. #29
    MA
    Liked: 79
    Brian,
    But if that's true, they would have widened the rear track by the same amount...no?
    I don't understand why the track was increased in the front by 1.1" and the rear by 0.875" over the years. If using the 4.5" wheel increased the track width by some amount, it would do so on both the front and rear equally. To me, it appears the track was increased for some other reason and wheel widths are not clearly the only reason.
    Has anyone ever measured these wheels? The offset may be the same as stock for all we know. VW never made a 4.5" wide, wide 5 bolt pattern wheel, so the offset is determined by whomever made those aftermarket wheels.
    I would think anybody that decided to make a disc brake system would have looked at the GCR, saw the max track width stated there, 52.5" front and 50.75" rear, and build within that specification. There are quite a few that have done this already. The Varicins and Advantage Motorsports are not the only ones to develop a package.
    The GCR says nothing about different track widths for different wheels and never did.
    It may have been a mistake
    on the part of the committee to not see the possible discrepancy and that's unfortunate. But there were 100 other FV owners that would make the same mistake.
  40. #30
    Torrington CT
    Liked: 482
    Andy,
    was as trying to find that out before you caught it but you beat me.
    ChrisZ
  41. #31
    Liked: 292
    The 'backspacing' of both wheels is the same. The change in width always goes to the outside. That is why I 'think' the track only increases .5". I have about three different makes of 4.5's and they are all the same. A manufacture would not to risk component interference by moving inward with the rim.
  42. #32
    Liked: 292
    Quote Originally Posted by ajpastore View Post
    It may have been a mistake on the part of the committee to not see the possible discrepancy and that's unfortunate.
    You are absolutely right. A mistake was made but you are focusing on just a handful (at this time) of competitors using disc brakes when you should be focusing on the issue that affects all FV competitors: Replacement Wheels. The 4.5 wheels were a replacement for 4.0 that are out of production. Sure there are 4's in the junk yards, but is that the class you are trying to promote. A class where the most competitive wheel has to be obtained from a junk yard and then refurbish. If they become the wheel to have what happens to prices and availability? This is why the 4.5's were given a track advantage. 4.5's are 2 lb. heavier and have 9" sq more aero frontal area (1.05 hp drag @ 100 mph for all 4 wheels). Those are some concrete negatives with the track increase being the only positive. At the heart of this is the 'perception' that you can be competitive with the only wheel that can be still purchased new.
    So some disc brake purchaser are going to incur some expense ( my 'estimate' not more than a 20% cost increase) if the track differential is maintained between the 4.0's and 4.5's.
    Beats the bad PR from the perception that best wheel is not easily available to everyone.
  43. #33
    The offset of both wheels is the same. The change in width always goes to the outside.
    That's not how offset works. You are confusing backspacing and offset, they don't mean the same thing.
    If the change in width always goes to the outside then the backspacing remains constant and the offset changes.
  44. #34
    Ohio
    Liked: 247
    4" wheels are easy to find, check the samba and you'll find a bunch. I'd bet that 95% of people out there are not running a 4.5" wheel and if some are then great! They're already at max track so no need to worry about spacers.
    I find it very ironic that we're talking about rules interpretation and what's for the good of the class. Who thought that the brake kits would end up being $3k plus? That wasnt how this was rolled out originally. Yes the costs savings will make up for that in the long run but you cant argue for the good of the class without stopping to consider that.
    So how do you make the disc brake kits cheaper? Easy increase track so its not so hard to fit everything inside the wheel. Keeping the track rule as is allows people to adapt existing kits to fit at a much reduced cost.
    So I think allowing spacers that are very inexpensive for the drums is what is best in this situation. Otherwise you'll have to buy your kit from one supplier who will then have a monopoly on the whole class.
    Plus what do you do for the 15-20 people with discs that would now be out of compliance?
  45. The following 2 users liked this post:
  46. #35
    Liked: 292
    1) If they are so easy to find then why were 4.5's approved over ten years ago. What a better image than a class that runs on junkyard wheels. Used wheels off Samba sounds very appealing.
    2) You keep making this about the disc brakes when it is really about maintaining the 'perceived' advantage of the 4.5's over the 4.0's. If anything, based on the data I listed the 4.0" should be handicapped even more that just the track adjustment.
    3) So you are proposing that all the drum users have the opportunity to invest in spacers. Unfortunately it is going to take longer threaded lug bolts or a conversion to studs to make a safe conversion. Not the cheapest thing to do considering the drum users were promised that they would not have to change anything to maintain competitiveness.
    4) So just how much cheaper are these new kits? I think you can not substantiate your claim of a cost savings. The Scaler kit indicated pricing very close to Varacins. Did they drop their price? I think not.
    5) I am willing to bet that there are fewer than 5 people that currently have a one of the 'wide' track systems. I know for a fact that the Varacins have sold 15 kits. Varacins does not have OR DESIRE a monopoly of the FV disc brake business. He got involved because no one seemed to be picking up the ball last year. Disc brakes was something important to the Varacins, so they were not going to wait around.
    Ohio
    Liked: 247
    1. When I was selling wheels no one wanted anything other than the slotted original vw wheels, the 4.5 wheels were made an option so people could buy new wheels if they didn't want to search for the originals.
    2. That must have been a quick trip to the wind tunnel to determine the drag on the wider wheels. Must have been pretty high tech with a rolling floor and everything (you cant just use surface area for something that moves). Also when you stretch a tire dont you think that the overall profile would change?
    3. Huh? Now you're over complicating it, go look at a drum kit and rethink how you can widen the track without all that silliness.
    4. Go look at the Chinese kits and the other ones on the market, they wont be as light as a drum or one of the kits made for FV but they work. Without that extra inch all of those cannot be modified to work.
    5. It was interesting how the rule was rushed out so quickly that only one manufacturer had time to go to market.
    There are many more than 5 kits of the wider brakes, but maybe some have been lost?? Seems like you're more in the loop.
    Back to the original point the rule was poorly written and some people knew this 4 months ago and did nothing about it until others had already created a kit. I go back to who was involved in putting the rule together?
  48. #37
    Burlington, WI
    Liked: 391
    Brian,
    You are speaking without a clear understanding of the facts and processes involved in the approval and creation of the disc brake kits. I've had several people ask me privately what your issue is, and I honestly have no idea. So far you are the only customer who retracted his commitment to purchase a system, and we refunded your deposit without questions even though we had already purchased the components to build your kit. With that being said, let me clear up a couple of things to try and help you understand how this all occurred.
    1) We did not do this with the intent of making money. It was clear upfront there was no way we could sell kits at a high enough margin to recover the engineering, prototyping, and testing costs. We did it to provide an available solution to the FV community for those wishing to eliminate the hassles and maintenance of the drum brakes.
    2) The rules were drafted during a long process between the entire FV committee and the F/SR committee. Throughout the entire process there were negotiations back and forth between the committees to create a rules package that was as balanced as possible. There were many instances where the F/SR committee (possibly under the direction of the CRB) pushed back on proposals by the FV committee as they felt it was too biased towards the discs. The entire process was done with the intent of not allowing the discs to have any advantages over the drums. Any proposal that could have been interpreted as favorable to the discs was rejected.
    3) We went through the engineering struggle to design a kit that was as identical to the drums as possible, as that was the direction the F/SR committee within the SCCA felt was necessary to get final approval from the CRB. This is also how it was pitched to the FV community so those with drums would not feel any obligation to change unless they wanted to.
    4) We were aware of the track width issue for a substantial amount of time (months), and have been working behind the scenes to get it corrected without the need to make it public.
    5) Based on the requirements from the SCCA throughout the rules making process, we felt there was no way they would allow wider track brake kits as it would go against all the restrictions we were held to and struggled to achieve.
    6) When the latest meeting minutes were released, it was literally a slap in the face that they would allow this to occur after the restrictions that were in place to get the rules passed in the first place.
    7) It has been proven many times before through SCCA actions that the cat out of the bag justification for allowing something to continue is not a valid reason.
    I hope that helps clear up any confusion this has created. Although we feel we are still in the best position by being able to offer both a narrow (for better aero) and wide track version, we owe it to both the early adopters and the FV community to fight to avoid any engineering escalation that will take the performance of the discs above those of the drums. After all, that was the entire premise on the allowance of them in the first place.
    Michael
  49. #38
    Medina, Ohio
    Liked: 174
    Brian,
    Michael
    Michael,
    You ask why Brian has an issue in regards to your original post? It's quite simple, he and others who are considering or those who have purchased kits from other suppliers don't want their kits to be deemed "illegal", and they're protecting they're potential or actual investment which they perceive you're trying to "Make illegal"....It's that simple really!
    If you and your Father will vow NOT to make an effort to have the alternative (to yours) Disc Brake Kits made illegal, then I'm sure those who currently oppose your efforts, will be glad to join you in making sure that the DRUM brakes are not obsoleted out of the class.
    Take care!
    Mark
  50. #39
    Ohio
    Liked: 247
    My issue is 4 months ago this was brought up, multiple brake manufacturers waited on the decision to allow the use of max track. The decision was made that per the GCR that was legal, so of course those manufacturers moved forward.
    Now 4 months later we're revisiting this after kits have been produced and people have spent significant amounts of money. Again this decision would make all but one kit illegal which to me isn't right.
    I dont like the behind the scenes political struggle and how people use their positions of power to sway things. I believe that's wrong which is why I'm voicing my opinion. Nothing against anyone personally but it's hard to have a committee rule on something when half of them bought the narrow track kit or developed it.
    I've said my peace, good luck to everyone this season.
  51. The following 2 users liked this post:
  52. #40
    Torrington CT
    Liked: 482
    Before everyone gets out of sorts on this, this is is nothing new to FV. we have been fighting rules clarifications for 50+ years.
    Lets assume there were no disc brakes.
    The track rule was written in 2006 to allow the 4.5" wheels.
    The goal was to keep the 4" wheels at 51.4 (no spacers) and allow the 4.5 to run up to 52.5
    The prime directive is - if it does not say you can do it, then you cannot do it.
    So if people are bending the turkey legs, putting extra spacers in the link pins or on the spring packs, offsetting the offset bushings * or whatever else in order to get the 4" wheels out to 52.5", then they are violating the prime directive and shame on us if we did not correct it sooner.
    *this is all speculation on my part, I have no idea what people are doing, other than I was told some people are....
    If Michael's system, whatever the cost, met the rules - technically AND in spirit - we have no complaints with him.
    What he and his dad seem to be claiming - is that people are or can push the rule in one instance to take advantage of a poorly written rule in another.
    This will happen every year until FV is buried in the ground as it is human nature to take advantage of rules to their benefit. And it is the responsibility of us who run under these rules, do decide if the fight is worth fighting.
    The question is: Is the wheel rule properly written? If not change it. If it is, then what other ramifications might it have on any other component(s)?
    ChrisZ
