I want to use an old bead seat, but want to smooth it out before I cover it again, will polyester resin eat the seat? How about good old bondo? I'm sure I could use epoxy resin, but it's a lot more expensive. Any ideas appreciated.
Mike M.
Mike M.
Yes and yes.
Bondo may eat it also. Think I remember something about painting foam with latex paint first but someone that knows more then me should advise you on that
Easiest is to brush on a layer of epoxy resin first, then the polyester resin or bondo.
Micro balloons can be used to thicken resin so it acts like a filler. Easy sanding. Lighter than Bondo.
One of the Ace Hardware stores here carries qt and gall cans but I’m close to a beach. West Marine has them I’m sure.
Great shelf life. Pretty sure it’s practically indefinite, unlike resin or Bondo.
John
Maybe I'm misinterpreting your intent, but wouldn't putting a "hard shell" layer over the beads significantly reduce their effectiveness in shock absorption?
