I am building a new set of hubs/uprights for my Car. There is nothing available off the shelf that will allow me to keep the suspension as it is. I’m frugal, and I also own a small CNC shop so making these will not be much of an issue. My question centres around the wheel bearing. Since I am designing this from scratch, I can choose what bearing I use. I would like to use an off the shelf readily available bearing. Double row angular contact, sealed bearing, but what load and RPM should I be looking at? I know my actual wheel RPM is around 2k, but should I be using say a 5k rated bearing or a 10k rated bearing to keep heat down?
For load, does anyone have a reference for static and radial loads? What are the ratings on say the SNR VD late model bearings?
