Results 1 to 5 of 5
    Kawkawlin michigan
    Post
    Having trouble finding points/rotor/condenser for Bosch distributor. Am I allowed to switch to electronic ignition running Club Ford in NER?
    If so, anyone know a good source?
    Post
    BAT has any part you need. phone: 941-355-0005.
    they have a web site too, i think it is batinc.com, but use your search engine to find it. also check out responses about failures of electronic units in other posts here before going to the pertronix units. carry a spare set of points, condenser etc with you at all times. cheap insurance.
    Kawkawlin michigan
    Post
    Thanks Rick-
    Just what I needed
    Liked: 909
    Post
    You also may want to contact Rick Hiland at RIC RACING (603) 224-9264 since he has set up about 6 or more of the Bosch units with the Pertronics modules for both CF and FF cars running with NER. They ARE NOT a simple drop in as you might think. Not if you want it done right.
    Bloomfield Hills, Mi., USA
    Post
    Before you go too crazy, make sure you've got a good charge in the battery.
    Geoff
