Results 1 to 9 of 9
    Senior Member bkd320's Avatar
    Evans City, PA
    Liked: 26
    Default Aim MXL Pro05 HELP!!
    I have an Aim MXL Pro05 on my Pro Formula Mazda (not PM18) and I have encountered 2 issues all of a sudden:
    1) My shift lights are backwards (at the low rev end, the LED's are red and at the high end the LED's are green). I have used the AIM Race Studio 2 to check settings and it's correct on the software. Any thoughts?
    2) My gear indicator simply isn't working! When I go to the ECM (Motec M800), I can see that the gear shift and no lift are working properly BUT no communication with the Aim. Any thoughts?
    Any help is appreciated!
    Buffalo, New York
    Liked: 269
    Quote Originally Posted by bkd320 View Post
    This may seem silly but are you updating the Pro5 from your computer?
    All else fails contact the Ferguson's at Veracity Motorsports.
    Evans City, PA
    Liked: 26
    Default Yes - using my laptop
    Yep, I am using my laptop to update. Is there a way to update the Aim without it?
    I am used to my sons Mychron which has a settings tool, but this appears to need to be updated by a computer.
    Another vote for the Fergusons at Veracity Racing Data.
    Londonderry, New Hampshire
    Liked: 102
    After you change the config on your computer, you have to transmit it. Have you transmitted or just updated things on the computer?
    Are other channels from the M800 being communicated correctly?
    Evans City, PA
    Liked: 26
    Default Transmitting.....
    Yes, upon review of the Aim inputs into the computer, I did a transmit and it is not changing anything.
    Interesting that you would ask if the M800 is communicating correctly, I did not that upon pushing the brake pedal it appears that the pressures are reading backwards. Having never diagnosed an M800 or Aim for that matter, I am unsure of how to proceed.
    Buffalo, New York
    Liked: 269
    Call David Ferguson.
    You may need a firmware update or a software update as mine uses Race Studio3
    Liked: 102
    His firmware has been mature for a long time, not that it may not be needed to be updated. The MXL Pista and Pro versions still and will always use RS2, not 3, for config and download. When RS3 analysis is available, all analysis will move it it.
    Liked: 102
    I've never head of anything reading backwards like you are having. I would suggest calling AiM at 540.342.9680 and talking to them. All of you hardware is mature, so it may be a simple fix that they know.
