Results 1 to 5 of 5
Thread: Novakar J9 F600
    Spring, Tx
    For Sale Novakar J9 F600
    1999 Novakar J-9 with J-10 updates
    2006 Suzuki gsxr 600
    Piontek billet oil pan
    Piontek paddle shifter kit
    2" axle and all peices
    dual Wilwood dynalite calipers on front
    Single Wilwood dyna light 4 piston on rear
    Dual Speedway oil coolers piped in series (makes for very large surface area.
    Braided oil lines
    SXS oil filter block off plate with -8AN connectors (eliminates need for getting into gallery plugs on end)
    Shoenfeld 4-2-1 exhaust that is in multiple segments so that you can install/disassemble without removing or tilting motor
    Brand new Fuelsafe fuel cell, not fully installed
    Holley Hydramat ( this eliminates the need for a high-low pump set up. that thing sucks fuel if just touching it - video of Hydramat
    Aeromotive fuel pressure regulator
    All fuel lines -6AN push type
    Hyper racing mod wiring harness
    modded stock air box - i was able to mod the box, rotate 180 to keep low profile and maintain most of the volumn. modified top and used foam filter material
    Pi system 2 dash with most needed sensors
    oil pressure and water temp sensors installed
    have oil temp, 2 rev boxes if decide to use coil pack connection for tach
    speed sensor - not installed
    plunge sensor - was used for rotation
    beacon sensor, beacon, and tri pod
    Spares:
    complete spare body
    a couple of sprockets, 39, 40, 15
    various length rods with spherical bearings
    2 brass radiators
    front control arm
    front hub that needs a little clean up
    front rotor
    rear rotor
    and some other misc.
    Not selling as race ready. Motor ran fine before getting new cell, old one had rot around fill neck but i still have it.
    I have been messing with this car off and on for a few years and just doesnt seem to be. Someone else should enjoy it.
    $9500 obo. - $9000 if before 08/26 as i am moving. This should be a super smoking deal to someone
    C.Scott Chesser
    ph - 8three2 8onetwo 52six4,
    text or call, if call please leave VM and i will call back.
    Huntsville, AL
    Liked: 57
    PM sent.
    George Bugg
    NovaKar
    F600
    PM Sent
    SF
    Liked: 18
    Default I think this is sold
    If you bought this car, please drop me a line...
    Member Lapdance's Avatar
    DFW
    PM Sent
    I highly doubt it but is this car still available?
