Results 1 to 10 of 10
    Senior Member iracer's Avatar
    Ottawa, Ontario Canada
    Default Can't shut off the engine
    Just had a new engine built and installed in one of our formula Mazda's and the engine now won't shut off with the ignition switch or the kill switch. Have to disconnect the msd box or turn off the fuel pump and let it run out of fuel. Any ideas what has caused this?
    Fallen Friend
    Pensacola, Florida
    Liked: 168
    Sounds like alternator is self energized... check against old stuff that did shutoff...make sure same and you hooked up same...
    Liked: 1262
    If the ignition switch isn't shutting off the power to the ignition then something is mis-wired.
    Also, if the cutoff switch is not disengaging the alternator, either it's the wrong switch (it should have an alternator cutoff) or it's wired wrong.
    cary nc
    Liked: 14
    Default FM
    The wire going to the alternator from the coil side needs to be in the horizontal position not the vertical. The back of the alternator has two male connectors on the back if the wire from the coil side is in the vertical position the car will not shut off.
    Thanks everyone.
    The problem was caused by a bad alternator. As soon as I replaced it everything work normally and the engine can now be shut off with the ignition switch.
    Liked: 804
    Quote Originally Posted by iracer View Post
    Thanks everyone.
    Any chance you could take a moment and clarify how the bad alternator caused that? thx
    I honestly dont know. I checked the charging and it was 18.75 v instead of the required 14.2v so I replaced the alternator and voila problem solved and now charging at 14.2v.
    Pittsboro IN
    Liked: 282
    Did you check the orientation of the plug on the alternator to make sure it was on the horizontal pin before replacing the alternator?
    Liked: 804
    Fred Michael: any chance of sample photos and a more detailed explanation? thx
    Bradenton, FL
    Liked: 14
    Quote Originally Posted by preston27 View Post
    Preston and Fred,
    You guys are on the right track with this answer but wanted to clarify it a bit more. There are two male connections in the back of the Alternator. Instead of distinguishing them as "horizontal" and "vertical", distinguish them as "Regulated Voltage" and "Unregulated Voltage". When installing the Alternator, you have to measure which one is which and connect the wire to the correct one. "Vertical" DOES NOT = "Unregulated Voltage" and "Horizontal" DOES NOT = "Regulated Voltage". I have replaced some that "Regulated Voltage" = the "Vertical". You just have to measure it before putting it on that wire.
    Jon Updegrove
    610-509-7321
    Jonupdegroveracing@gmail.com
    -Head MRTI Indy Lights Mechanic: -Head SCCA USF4 Mechanic
    -Lead Cape Motorsports Mechanic: -Head PWC Audi R8 Mechanic
    -Lead IMSA LMP2 Mechanic
