Have lots of parts for sale. Will do an inventory in the next few weeks. Let me know know what you need. Mostly used, some new.
Dog Bones king pin carriers $20 each left (2) right (4)
Inner wheel Bearing spacer $3 (3)
Thrust washers $2 (7)
Torsion bar inner locator (removed for adjuster) $3 (4)
Spindle nuts $1 left (9) right (7)
Torsion arm clamp bolt (og will need cleaning) $1 (5)
Frame to beam bolts $1 (4)
Steering box clamp $ 5 (3)
NOS link pin set (no box) orings dried up $25 (1)
Link pins good used $2 (13)
King pins good used $2 (4)
Grub Screw & nut $1 (25)
Link Pin Bushing New $2 (6)
Link Pin Shims used $.25 (lots)
King Pin Thrust washer carrier (piece with two nubs) $1 (7)
King Pin Phenolic washer used $1 (13)
Wheel bearing taper inner new $5 (1)
Wheel bearing taper outer new $4 (3)
Ball bearing inner race only $2 (3)
Ball bearing outer race only $2 (2)
Upper trailing arm $10 (lots)
Small parts ship in whatever fit in uspbox for$6.50
Larger parts for $13.50
