I am setting up both a Zink z10 and a Crossle 55f. Having read the thread where Steve Lathrop made recommendations of 1000/900 for the Zink based on motion ratios, I measured the ratios on the Crossle. I came out with .50 at the front and .86 at the rear.
Using the formula: wheel rate =spring rate x MR x MR or spring rate = wheel rate / MR x MR and wheel rates of 235lbs for the front and 350lbs for the rear. I came up with spring rates of 940/472. This is far different than the recommended set up of 400/350 that came on the Crossle.
The above numbers were based on WR=Corner weight. If I correct WR=Corner weight-unsprung weight then I get 235-50=185 and 350-50=300 for the F and R. Plugging these into the equations still gives me Front SR=185/.5x.5=740 and Rear SR=300/.86x.86=405. Still 740/405 is not near the 400/350 recommended.
Any insight into the difference would be appreciated.
Robby
