Results 1 to 27 of 27
    Liked: 1262
    Default Tire Rack - Flat against the wall style
    I've seen pictures of trailer with tires stored flat against the wall instead of on a typical tire rack.
    Are those all home made solutions or does anyone sell those?
    Sarver, Pa
    The tires for my FA were so big , that's the way I did it. I built my own simple fold up racks with flat bottoms and used a couple eye bolts screwed into the wall and a tie down strap to hold em tight. 2 fronts on one side , 2 rears on the other.Worked great.
    Liked: 554
    I built my own and referred to them as "tire shelves". You can see a picture of them in post #17 in this thread:
    http://www.apexspeed.com/forums/show...iler-Tire-Rack
    Lurker Keith Carter's Avatar
    My Desk
    Liked: 447
    Our original trailer had them. They were custom made solid aluminum posts to the correct offset for fronts and rears.
    2003 VanDiemen FSCCA #29
    Liked: 1262
    Thanks for the ideas.
    Yes, space is the reason. I'd like to eventually build a stacker so I'll need side clearance.
  9. #6
    Northern NJ
    I made a few sets for myself & others on this board. Might give you a few ideas. There was a bit of machining so that the wheel sat firm on the mount.
    Senior Member xmazdatracy's Avatar
    behind you
    Liked: 130
    Someone just needs to copy this pit-pal design. https://www.pegasusautoracing.com/pr...asp?RecID=6377
    Maybe a group buy or something... I know a good fabricator.
    Contributing Member northarrowracing's Avatar
    Rougemont, NC
    Liked: 36
    Default tire holders
    What you want are made by a company named Pit Products, not Pit Pal. Individual tire or wheel brackets, for $29.95 ea. I have 3 mounted on the wall of my trailer. Here is the only problem. My rain tires/wheels fit just fine but my panasports/drys have a center hole that's just a little too small ( I have 13" rims ) and will not work. If you are hanging tires alone, without wheels these things are wonderful. You can put a half dozen all over the walls of your trailer.
    Ric
  13. #9
    behind you
    Liked: 130
    https://pitproducts.com/collections/...ucts/tire-hook
    I like the large back plate that will run up and down the trailer rib/stud. However the post which holds the tire are just a welded in angled piece. Not a straight piece in which you can fasten the tire in, via a pin or a threaded device. I have had a few things fall from the walls of my trailer and its never a pretty scenario. But for 1/6 the price of pit-pal I am sure I can approve on that product on my own.
    Thanks for the lead!!!!
    Liked: 58
    Quote Originally Posted by xmazdatracy View Post
    Wow, the cost on that is insane! Is it gold plated?
    1993 Citation FV
    NEFV - 2022 Champion
    NERRC - 2022 Champion
    Wetmore, CO
    Liked: 111
    I used two eight footers by Pit Products in my old trailer. When setup for my Stohr Wf1 The had 4-6" space away from the wall. Was able to use OEM screw holes in the exterior to go right thru to the inside. You will notice I used the front four feet of each rack for bin storage. I had the ceiling height.... and I am short. So. I was lucky enough I had the room to use traditional racks. Lack of space and storage required it - Was an LQ trailer with short cargo space.
    My buddy cut the width down on his so they didn't stick out from the wall so far.
    Good Luck!
    Classifieds Super License andyllc's Avatar
    Columbia, SC
    Liked: 201
    Have you thought about e track on either side of the trailer with aluminum beams going across the width of the trailer to store your tires? Takes up very little wall space and utilizes the space in the middle of the trailer that is usually wasted. I have two sets of two aluminum beams, one holds my tires the other holds a bunch of plastic storage bins.
  17. #13
    Liked: 1262
    Quote Originally Posted by andyllc View Post
    Pictures?
  18. #14
    Chatham Center, New York
    Liked: 863
    I second Andy- I set up a pair of shoring beams with E track across the trailer ( https://www.shipperssupplies.com/alu...oring-beam-102 ) and could usually put two sets of F2000 tires and then some on a singe pair.
  19. #15
    Liked: 804
    Pictures?
    this idea works, but its the polar opposite of your original question :-)
    Member madgameracing's Avatar
    Falls Church, VA
    Pictures?
    I had this setup, but switched to a flip up wall mounted tire rack.
    Mike
  21. #17
    Columbia, SC
    Liked: 201
    Pictures?
    See Lotus7's post here. That's the idea although mine are up high so the car can roll underneath
  22. #18
    Liked: 804
    My photo was a fast internet image grab, I don't have that setup in my trailer and won't again. More cons than pros in my opinion :-)
  23. #19
    Columbia, SC
    Liked: 201
    Hate to hear you had issues, none for me (knock on wood)
    I run a strap through the middle of the wheels/tires to prevent them from going anywhere should they want to fall out. I couldn't imagine doing it any other way.
  24. #20
    Senior Member Dave Cutchins's Avatar
    Grandy, North Carolina
    Liked: 17
    A simple and inexpensive solution is to mount E-Track on the wall and weld the appropriate length and size bolt to an E-Track clip. and mount the tire with the correct size washer and lock nut.
    Dave Cutchins
    Stohr F-1000
  26. #21
    Liked: 1262
    Quote Originally Posted by Dave Cutchins View Post
    That's what I'm thinking through at the moment.
    https://www.amazon.com/Enclosed-Comp...ds=tire+holder
    or similar things like:
    https://trailerparts.com/spare-tire-...less-rims.html
    http://www.flaman.com/parts/index.ph...re-holder.html
    But I keep going back to the 'bucket' idea:
    http://cargopal.com/store/?model_num...older_050912B1
    The reasons are:
    Less hassle than 'fastening' something through the middle.
    You could store a tire no wheel.
    You could store a bagged tire.
    Cost - gotta find cheaper buckets!
    Essentially I think I'm looking for a tire size version of this:
    https://www.summitracing.com/parts/a...2259/overview/
  28. #22
    Nazareth, PA
    Quote Originally Posted by northarrowracing View Post
    Ric
    You think those Pit Products mounts would work well for trailer spares? I'm nervous about the wheels potentially bouncing off the mount as there's no way to secure them, but maybe that's not actually a concern?
  29. #23
    Rougemont, NC
    Liked: 36
    Quote Originally Posted by PGas32 View Post
    Should not be a problem as the part that holds the wheel is at about a 75 degree angle. I have 3 on the wall and just to be sure I have a lightweight tie down going across all 3 and hooked to the wall on either side I would never want a wheel to get loose back there.
    Ric
  30. #24
    Port Ludlow WA
    Liked: 115
    Default Tire racks
    I have a set of the flat tire racks I purchased here on apex that I can no longer use. Pm me if interested.
    Tom
  31. #25
    Liked: 804
    I used this simple piece for my trailers' spare tire, against the inside wall, albeit with the floor taking the weight.
    And you can get a dozen of them for the cost of a single Pegasus version .... :-)
  32. #26
    Nazareth, PA
    Just ordered two of these, should do the trick. Thanks!
  33. #27
    Wetmore, CO
    Liked: 111
    Default Also use these
    I use these too (or similar solution - the utility version) for my trailer spares (2 spare tires in my trailers) - in my past two bigger trailers. I mount them near the rear door with the rubber on the floor, replaced the bolts with ones that were appropriate for my offset and added threaded "t-handles" to allow for easy quick removal (amazon or your local hardware store).
    I am too cautious to trust them at an elevated level with race tires.
    Best of luck
    CJ
