Results 1 to 5 of 5
    Member T540's Avatar
    Perth, Australia
    Default Annular clutch release bearing reliability.
    Just wondering if anyone can give me some info regarding the reliability of the Tilton series of annular clutch release systems.
    SAAB road cars have a system which can be fitted with some effort at a fraction of the cost of a Tilton but I'm also not sure of its reliability.
    I'm thinking of fitting one to my '82 Van Diemen but I don't want to be having to pull the gearbox off too often to change seals.
    Thanks in advance.
    Senior Member Nardi's Avatar
    Southeast
    Liked: 121
    I put a Saab unit in a couple of 84 Reynard's and they worked flawlessly. Changed the T.O. bearing whenever engine was pulled.
    Memphis, TN, USA
    Liked: 416
    Properly installed the Saab units are bulletproof. Any misalignment will result in premature seal wear.
    Charlie Warner
    fatto gatto racing
    Liked: 1415
    The SAAB units were standard on the Citation FF/FC cars starting in 1987. Very reliable.
    The mounting bracket is simple but remember that the assembly is held together by the bolts that mount the cylinder. So the bracket needs to be well thought out.
    Liked: 3326
    Default SAAB 9000 clutch slave unit seals
    Be careful where you get replacement seals - I did not have good luck with some I got off the Internet.
    I wound up buying proper high-temperature peroxide-cured EPDM seals on special order with a reasonable minimum quantity from a reputable company: All Seals, 714-556-4931 (California).
    My contact was Mike Leach, mleach@allsealsinc.com
    If you mention my name, he still may have the records of what I bought.
